Northwest Central Dispatch Programming Issue
divemedicdrb
Mount Prospect IL
Hey Guys
I just programmed my Uniden BCD 996t for Northwest Central Dispatch using the following programming, but the transmissions are interrupted every 2 seconds or so for a brief silence then I hear the transmission again. It never leaves the TGID, the voice just cuts out, every time. I checked and as far as I see, I have no priority scans on. Anyone know the problem?:
Frequency LCN L/O Vol Adj Num Tag
851.08750 0 False 0 NONE
853.07500 0 False 0 NONE
851.53750 0 False 0 NONE
851.78750 0 False 0 NONE
856.71250 0 False 0 NONE
851.83750 0 False 0 NONE
852.31250 0 False 0 NONE
853.75000 0 False 0 NONE
Use Motorola Status Bit
Use Motorola End Code
Ignore Digital Motorola End Code
Enable I-Call
Site Type: Mot Custom/Reband
Control Channel Only
Band Plan 1 - 851.0250 854.0000 + 25Khz 440
Band Plan 2 - 851.0125 868.9875 + 25Khz 0
N9JIG
Sheriff
Moderator
Far NW Valley
Sounds like you have CloseCall or a Priority Channel enabled. Turn these off and see if that goes away.
