Not streaming online
mjbjr
Macon,Ga USA
I can hear the scanner working but somewhere between it and broadcasting, it's getting lost somehow. I restarted scanner and PC, re-detected IP and and restarted pro scan and still nothing
Sds200 Macon -bibb county Ga
ProScan
Software Provider
Ontario, Calif.
Are you using the Source Client, RSOIP, or Web Server feature?
Is the whole connection not working or just the audio not working?
What have you done to troubleshoot this?
mjbjr
Macon,Ga USA
Source client
audio via app not working but coming in on scanner
Troubleshoot..restart phone,pc,program,scanner and reconnect it, checked cables and all are tight and plugged in
ProScan
Software Provider
Ontario, Calif.
That screenshot should be a hint. The scanner is not communicating with ProScan
Go to the Comm. Port then click the URL Setup button.
Do you see the RX and TX bytes counters incrementing or do you see errors.
Read the tip at the bottom of the URL Setup window.
mjbjr
Macon,Ga USA
Ok that was a step i couldnt find earlier but its up and running now. The RX and TX are increasing with no errors. But its still not coming through online and all the archives are 1-2 seconds long
ProScan
Software Provider
Ontario, Calif.
Start with the recordings and resolve that first.
The duration should match the duration of the transmission. Perhaps the Resume Scan/Search on? It's located in the upper right corner of the program.
mjbjr
Macon,Ga USA
Can't believe I never noticed that icon before. Here's what it says
ProScan
Software Provider
Ontario, Calif.
That looks okay. Something is causing the recordings to be 1 to 2 seconds in duration. I don't know what would cause it. Are all recordings the same? Does the history logging show the entries to be 1 to 2 seconds in duration.
ProScan
Software Provider
Ontario, Calif.
Regarding the streaming issue: Did you click the Connect button in the Source Client tab and does the log (on the right side) shows it connected? Can you post a link to your feed?
mjbjr
Macon,Ga USA
The log directly to the right under source client was blank. Under history logging it shows
  • History Logging.txt
ProScan
Software Provider
Ontario, Calif.
Here ya go
I see you do not have URL selected for the input. Turn off the Source Client then select URL in the Input Sound Device box. Click the URL Setup button to verify the RX and TX bytes are incrementing and do not show errors.
