BCD436HP/BCD536HP: Nothing to Scan still a Problem
crowleyd102
St. Louis
I've been through Trunker's X36 "Nothing to Scan" Checklist twice, and I'm still getting this message with one of two favorites lists.
I've tried to fix the Quik Key several times along with all the other settings mentioned in the Checklist, both in the scanner and in BCDx36HP_Sentinel.
When is asks me to set the Quik Key for the Favorites List, I scroll down the the number 2, I press Enter key, and back out using the menu button.
I also check Quik Key Status.
If needed I could my profile and HPD files.
Thank You
N0HMI
crowleyd102
St. Louis
Post your Sentinel export as an attachment on this thread. Someone can check it over for errors. Directions here
I had to rename the extension from "hpe" to "txt" to get it to upload to RR. I hope you can rename it back to "hpe"
  • MO State Patrol.txt
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
As mentioned previously you didn't program any sites to be able to hear traffic. Go ahead and give this file a try. I may have imported the wrong site though, wasn't sure if you needed St Louis City/MSHP or Weldon Spring
  • MO State Patrol.zip
crowleyd102
St. Louis
Here's what I see with your .hpe file. I guess I've forgotten how to navigate Sentinel.
Thanks for all your help!!
ofd8001
Louisville, KY
Put in your local weather channel and see if it will scan and stop there.
If this is a trunked system, which I believe it is, you cannot add the conventional weather channels. Conventional and trunked "stuff" cannot be intermingled.
That said, weather channels are excellent diagnostic tools for trying to figure out problems with conventional systems.
ofd8001
Louisville, KY
Yes, you must add sites, preferably those closest to where you are, in order to monitor the system.
Trunked system scanning requires both entries for sites and talkgroups (or ID Search On).
Whiskey3JMC
Philly burbs 🇺🇸
That doesn't look like the file I sent (unless you renamed some things), did you click File > Import from .hpe file in Sentinel then point it to where you extracted mine?
crowleyd102
St. Louis
Can you take a look at this file? I believe I have the sites turned on. I tried to turn on location on the BCD536HP, but it doesn't seem to hold the zip code (63119) that I entered.
Thanks again,
Dave N0HMI
  • MOSWIN.zip
phask
zanesville
Thanks again,
Dave N0HMI
You have sites, looks like all of the state. Now avoid all that are not in your area (2-3).
crowleyd102
St. Louis
Done: Service types, Location, FL Quick Key, and Scan Selection checked. Still, nothing to scan.
Again many thanks.
Whiskey3JMC
Philly burbs 🇺🇸
