NX-5000 Series, Q&A, Info, and details
kd4efm
Florida
Thanks Evans for the helpful advice it really saved me some time!! OK So I have them both connected and up and running, I see what your saying about making each one scan but only the selected radio's audio is routed to the speaker in the head, If I connect a speaker to each deck will I then be able to hear if traffic comes across the unselected deck? Also I want to ignition sense with a time out, do I program the "A" deck which is master only and connect only it's Yellow lead of do I have to connect both?
Thanks!!
Ignition sense just A deck, correct.
Two speakers on each deck, yes.
You can tell how low you want the unselect in 3 levels.. set the speaker to external I think, but I recall it can be set to both in and out.
kd4efm Evans, sent using TapTALK on my HTC M9
RK3AAG
Russia
Guys, who can explain differencies between KAS-12 and KAS-12DU? Second one has bigger installer and contains DB suffix. I can suppose that it includes built-in database server, but not sure.
RK3AAG
Russia
Guys,
Who can check KSC-Y32 availability date from Kenwood USA? Can't get it during 2 mo.
ke6yjc
Fresno, CA
Has anyone experienced the issue where the date / time is back to factory when using a GPS antenna connected? I'm not 100% sure this is the cause, but I noticed that when I seutp the 2nd Deck that I've lost my Date / Time on Deck A. I can't figure out why it's showing 00:00 and 1/1/XXXX Now all my recordings are showing 00:00 --/--/-- and it's kinda useless. I did notice that Deck B is showing the proper timestamp when I switch the display to Deck B.
krokus
Southeastern Michigan
Does the GPS interface with the deck, or the head? If so, is the GPS connected to deck B or A?
Sent via Tapatalk
ndejohn
Middletown, Connecticut
Hello Everyone!!
I am looking to purchase a NX-5700/5800 with the enhanced, single control head in the next few weeks. I am a big Motorola guy and have been for all my life. What has finally pushed me over the edge to Kenwood is the ability to have multiple platforms in on chassis. For example, I am looking to have P25 in my NX-5700 chassis and P25 & DMR in my NX-5800 Chassis. To do this with Motorola, I would need to have several separate radios and spend well over $10K.
My question that I have, and I have ready through this entire forum is this..... I have several MotoTrbo DMR systems up and need to have access to them as well as to P25 channels and analog channels. Can I do all of this in one chassis and what features of the MotoTrbo from Motorola will I be able to get in the Kenwood? Will I be able to see ID's and so forth?
I'm wondering if someone can elaborate in it for me a little more in depth on the DMR/MotoTrbo side.
Thanks,
Nick
rescue161
KE4FHH
Hubert, NC
Hello Everyone!!
Thanks,
Nick
You'll be able to see the ID/Name as long as you program the name that is assigned to each ID. Boot time is amazing. MUCH faster than the XPR5550. Pretty much the only thing that the Kenwood won't do is roaming and Motorola trunking (Connect+, Capacity+, etc). I do miss the roaming feature, but I don't travel much, so I can live with that.
I have my single chassis NX-5800 set up for analog, P25 and DMR. It does all three perfectly.
RK3AAG
Russia
NX5K is pretty good vs Moto, but there is no BP/EP and ADP. Also, sound in P25 noticeably differs from Moto and some of your friends might not be recognizable at the beginning of usage.
n3obl
Ø
PA
Is there any compatibility with the Mototrbo gen2 radios that have the built in AES?
RK3AAG
Russia
It must work, because Kenwood's AES-256 module is FIPS certified and keyloaded by Motorola KVL. But Motorola changed AES-256 since 2.4 TRBO release. So, you must check compatibility with old and new FW. One of them will not work.
ndejohn
"BP/EP", what is that? As for encryption, none of the systems I am running have active encryption.
otobmark
NC
I'm planning to replace my moto gear in next week or two and have read this thread with great interest. My confusion is software. My dealer said good luck with moving software from one computer to another. He's out of town for awhile so in my impatience I'm asking here. What is the deal with KPG-D1(NK)? My moto software is on several computers but only my radio laptop has entitlements loaded. I can creates code plugs on any of them but only the laptop can shoot the radio (well, with entitlements anyway). So what's the workflow with Kenwood? Can I unauthorize software on one computer and then authorize on another? Is the process easy and unlimited? Is the software entirely locked without authorization or only the shoot radio part? Desired is to create plugs on desktop with large monitors instead of tiny laptop screen and then load radios with laptop in the field. The term authorization may be incorrect, whatever Kenwood calls activation.
Hopefully someone on thread sees where I'm headed and Give me a best practices. Multiple licenses is not necessarily a deal breaker but I will only have 4 or 5 radios.
rescue161
KE4FHH
Hubert, NC
The software won't even run unless you buy a license, so if you just want to edit on one and program with another computer, then you need to buy two licenses.
otobmark
NC
Ok. Unnecessarily cruel but now I know. What about moving license to a different computer? If you replace pc do you lose license or can you migrate ? I'm having a hard time understanding their motivation.
I am a lineman for the county.
The software licenses can be migrated to another PC, but you have to work with Kenwood to do it.
Yeah, it's a pain in the butt, I agree.
But, with so much radio software being uploaded to the web, they do lose money on it.
Personally, I think it's a bit extreme. Being able to have it on a laptop and a desktop is something I prefer at work. Maybe some day they'll loosen up the restriction.
rescue161
KE4FHH
Hubert, NC
Even if you buy two licenses to use on a laptop and a desktop, it's still cheaper than Motorola. Granted, you don't have unlimited install, but at $115, it is not bad. At least it isn't $2500 for each install, like Harris.
otobmark
NC
Ok, I get the basic idea. Adobe and others have automated affiliations so you do you own switching. In fact your cellphone company lets you switch phones through web. From my experience with Kenwood analog radios I realized programming software was not their strong suit.
Can't believe Motorola is less of an *** than Kenwood on anything!
Oh, how hard/expensive to REMOVE an advanced system key from Kenwood? $400 on my apex!
Markb
Planet Earth
I have been able to move my license back and forth between PC's, provided that I can deactiviate the license on the uninstall computer.
I did have a catastrophic failure with a laptop and had to call Kenwood since I couldn't deactivate that one.
Sent from my SM-G935V using Tapatalk
