NX-5000 Series, Q&A, Info, and details
otobmark
NC
Ok, it allowed me to get to text screen and write and send. The send transmitted but was unsuccessful. I'll have to look at Motorola side. Since I've seen a lot of one way texting when mixing any brands of radios I'm not surprised. You'd think if it works in one direction that it would work both ways but that has often not been my experience.
How is the nxdn compatibility across brands of radios on texting etc?
kd4efm
EL98 Florida
Icom and kwd sms fine.
Sent from my SM-G935P using Tapatalk
otobmark
NC
You remember right. I got it to work up to a point. I could create and send a text but Motorola didn't receive it. This issue of one way texting when mixing different brand radios has been an ongoing problem with Dmr. You'd think if it works one way it'd work the other.
How is nxdn on such issues with mixed brand radios?
otobmark
NC
NX5300 Direct Channel Shortcut
I can't get Direct Channel to work. I'm unable to enter data into the 6 slot table and also cannot set up a shortcut key or even menu selection. Is there a trick to this?
kd4efm
EL98 Florida
Define 6 slot table, I'm confused. Direct has two modes, you will need to look up my email and send me your email, I will send you the programming guide for DMR.
otobmark
NC
OK.
Key Assignment>Direct Channel (there is a box with 5 numbered slots--all greyed out). I'm trying to set up direct access to 5 preselected channels by long press on numerical keypad.
kd4efm
EL98 Florida
Stand by, I'll look that up. Did you hit F1 and read what requirements to be met for it in the help file. That's the quickest way to get it done, I'm driving.
kd4efm
EL98 Florida
OK.
Got to your hot key (dtmf 1,2,3,4,5,6) set it to direct 1, go to direct, set zone and channel.
So far?
otobmark
NC
OK. Got Direct Channel up and running. It was the order I had wrong--I needed to set shortcut keys 1st and go back to list to set zone/channel. I added menu items for direct channel select so I can now reprogram from front panel. My only fail was in using operator selected priority scan. I set it on the scan list and then added menu item for priority select. When I try to use priority select it bonks so I never get to the next screen (Priority1, Priority2). I'll pound on it tomorrow.
otobmark
NC
No joy on selectable priority yet. It works with Zone Scan but NOT Scan LIST. Took a break from that to re-test texting. I can send text from Motorola to Kenwood--goes through almost instantly. I CANNOT send text from Kenwood to Motorola. Played with preamble etc. Motorola texting set to DMR STANDARD (Not Proprietary). Went through my repeater for test. I don't see a messaging delay on Kenwood options as I do on Motorola, if that matters. Cross Manufacturer texting always seems a challenge, wonder why? I've seen this "one way" texting with other brand combinations before as well.
Colton25
Does anyone know if the actual plastic screen is separate from the radios housing or is it all one unit?
damo76
Kenwood NX5700 / 5800 Site Roaming
Has anyone managed to get a NX5700 / 5800 to site roam in DMR mode? I'm using mine with the common control head option. Can't find an option to roam in DMR mode - only in NXDN mode. This can't be true?
kd4efm
EL98 Florida
Dmr roaming is in the DMR field near the bottom of the left side.
ndejohn
Middletown, Connecticut
Question, I have a button programmed for "Home". When I press it, it brings me back to my home channel, but as soon as I enable scan, it moves back to the last channel I was on. Any ideas?
damo76
I can't see that. If I open the DMR section, I have four headings - DMR Information, Individual ID List, Group ID List and Status List. None of these contain anything about DMR Roaming. I am operating in conventional mode. Is there something I'm missing here?
Thanks for the reply.
crazyboy
NJ
Create a dmr site roaming personality, enter a your repeater info and check the box that says active site hunt, add all the repeaters you want it to roam between in this personality. Then in zone channel you can choose just one of these repeaters as it is going to automatically roam between each one in that personality.
ndejohn
So, I have a question.......... I have a 3-site, conventional DMR, UHF system. Each site has a single, UHF, DMR repeater and both color codes are active. I have three groups set up:
Group 101 uses CC: 5 - TS: 1
Group 102 uses CC: 5 - TS: 2
Group 150 uses CC: 5 - TS: 2 (and programmed to only work when the other talk group is not busy).
Now, my question is do I have a personality for each of the above, or do I just set up the the site repeaters with the color codes and assign it out in the zone?
damo76
Thanks for te replies. Is it possible for me to send you a code plug, as I can't find these settings anywhere in my system. Even if I use the personality based view - there is nothing about site hunt.
Please PM me with an email if you're happy to look at this.
