NX-5700 Shutting Down While in Scan
LubeckTech
Parkersburg, WV
We have 2 5700s that are just over 2 years old and have worked fine up to January.
They now both will cycle on and off only while in scan. they both lose RX and display but are not rebooting.
Has anyone experienced this???
I am going to update the firmware but don't think it will help.
LubeckTech
Parkersburg, WV
The problem was not hardware relater nor firmware related but software.
I updated the firmware to 5.23 with no change. I cloned the codeplug in another radio and had the same problem.
The radio had two zones which were populated using personalities. One zone was populated with personalities from a conventional analog system with nothing but analog personalities and scanned correctly. The other was populated with personalities from a P25 Conventional system populated with analog and P25 personalities and had the problem of continually shutting down in scan. I created a analog conventional system with the analog personalities from the P25 system and recreated the problem zone with the analog personalities from the new system and 2 P25 personalities from the P25 system. Deleted the problem system and scan worked correctly. The only thing I can figure is the problem zone was corrupt or the P25 system was corrupt. It is also possible having analog personalities in a P25 system was confusing the radio but we have set systems with analog personalities in a p25 conventional and it has worked alright.
