NX-820HG-K2 Programming Issue
100pcttn
Dickson,TN
Help!
Good morning,
While programming one of our new radios here, I "think" I must have overwritten the radio with programming from another radio, and now all the unit does is "beep - beep - beep - beep" the entire time it is powered up. I'm using software KPG-141DN version 4.80.
What have I screwed up bright and early on a Monday morning???
Thanks.
100pcttn
Dickson,TN
I would have thought so too, but when I upload valid programming from another NX-820 from this same batch of radios, then download it into the "beeping" one, it still continues to beep as soon as it comes out of programming mode.
First time I've encountered something like this.
Thanks for any and all assistance.
100pcttn
Dickson,TN
That's it!! One is a K and the other is a K2. Bought them both at the SAME time! Ok...now what do I need to do to fix the K2 "beeping" unit?
kd4efm
EL98 Florida
Dump a blank 450-520 in it.
First export your current info from the good, save it. Open a new file, change property to 450-520, import your info, write it.
kd4efm Evans, sent using TapTALK on my HTC M9
100pcttn
Dickson,TN
And still it beeps! Here is what I did:
"Read" info from working "K" radio.
Exported it.
Started "new" file.
Set frequency range to the 450-520 selection.
Imported the previously exported file.
"Write" programming out to the "K2" radio.
And still it beeps!
kd4efm
EL98 Florida
Did you get the out of ranger error before programming?
kd4efm
EL98 Florida
Exported it.
Started "new" file.
And still it beeps!
okay, i see your doing now....
the K is the master radio, the k2 is the NEW.
K2 is 400-470
swap same process...
K2 to gets K import, make sure you set range first, then program it.
efm
100pcttn
Dickson,TN
I can't remember for sure. It's possible, I've been checking and it seems the dealer mixed in a K2 in with my K units. If I can't undo whatever I did this morning, I'm sending it back for a swap so that all my units are the same.
I'm just a Plant Manager...not an expert at radio model differences! LOL
Thanks for any help you can throw at me!!!
100pcttn
Dickson,TN
That did it!! The radio is silent! LOL
Thanks a million. You guys on here are the greatest. This is twice in the past couple years I've turned to this site for help, and twice that I've come away with new knowledge, and a problem solved!
Happy Thanksgiving!!!
kd4efm
EL98 Florida
Glad to help.
HAPPY GET FAT DAY
