NX220, no channel names/tags
KB1VLA
South Berwick, ME
An odd problem has come up when programming my NX220 (firmware 1.23) with KPG141DN (ver 4.80). I've had this radio for a few years now, but haven't had to do any programming with/to it since I got it. I recently went to change the programming (add/delete a few channels) and although the programming was successfully written to the radio, the channel names have changed to just the zone and channel number ("1- 1" for example) instead of the name/tag I have in the software. The only thing that is different from when I originally programmed this radio is the USB programming cable; in the past I used a generic aftermarket cable that I misplaced and I replaced it with this one: NX-220 FTDI KPG-22 6 ft Radio Programming Cable
I can successfully read/write from the radio with this cable with the exception of the channel names.
I'm betting there is a box somewhere I accidentally checked or unchecked, what do you all think?
Yes.
But my programming laptop is at work, and I only have a few NX-420's, so I don't recall off the top of my head.
kd4efm
EL98 Florida
Channel display in key assignment must have been added. Had a nx5300 user do the same thing. Undo what you added.
