k3fs
OFT has always missed transmissions. P25, DMR, or NXDN, all have the same problem with missing transmissions. This has been the case even with the 396XT on P25 OFT. Uniden has failed to address this for years.
I think the 436/536 are doing a very decent job in picking-up NXDN and DMR OFTOFT has always missed transmissions. P25, DMR, or NXDN, all have the same problem with missing transmissions. This has been the case even with the 396XT on P25 OFT. Uniden has failed to address this for years.
It's the TG that has a delay, not the frequency, and it will switch to another frequency even during a TG delay time. That goes for both Uniden and Whistler scanners. There's a high risk using 0 TG delay that the scanner will pick up another TG to monitor before the original TG gets acitve again and you'll miss the response. Use a long TG delay time like 5-10 sec to not miss any replies.Also remember that by default each P25 frequency, or talk group has a 2 sec delay. In a trunking system, a reply can move to a different frequency and you will miss the response. So I always set any thing on a P25 trunking system to 0 sec, delay. I am pretty sure this would hold true for any true trunking system.
You can say that a Whistler TRX scanner will scan some trunked systems the same way that a Uniden will conventional scan digital systems, it will check if the frequency has a carrier and then try to decode the datasignal until it gets enough information to decide what to do, or if no data can be decoded it will time out after a longer time. And as have been pointed out, Unidens conventional scan often works better than OFT as it's control channel data decoding seems to be flawed.
/Ubbe
Some questions and/or feedback from engineering:
1. werinshades
NXDN OFT issue for TGID 0 both x36 and SDS, Conventional is no issue
Does it only miss TGID 0 or are others missed, as well?
When you delete TGID 0 and use ID Search, are the comms caught??
Could you get both NXDN OFT and conventional logs simultaneously using SDS 100 and 200?
Thank you so much for your response,Some questions and/or feedback from engineering:
3. VE2ZPS
DMR, NXDN OFT, and Conventional issue of SDS, x36 is no issue
Try different RF Filter settings.
Also, could you get the problem OFTs and conventional logs simultaneously using SDS and x36?
from the logs, RSSI is -105 to -120 dBm. This is too weak for reliable reception and any interference at all will only make it worse. Need to improve signal, first.
Ok but since the Global Auto Filter have the same options available as what we can apply to individual site I assume it means that the different filter options available for individual site have already being tested when applied at the Global level (i.e. to all the sites) ?Please change Global Auto Filter under Settings and find the optimal filter.
For each OFT site, the optimal filter may be different.
Once you determine the best for a particular OFT, reflect the filter setting to each site
By the way, when OFT is not received well, is that information displayed not only on Proscan but also on the scanner?
By the way (I forgot) - When I bought the SDS100 and SDS200 I assumed that the DMR/NXDN OFT were at least at par with my 436/536
What is so wrong with the SDS that I have to play and try different option with each individual set-up of 50 (plus) sites just to try to improve the situation because they are receiving less than 50% of the transmissions while the 436/536 are doing such a wonderful job ?
I am an extremely loyal Uniden client (for so many years) and i am asking this question with the outmost respect
(but I dont understand what you did knowing that the 436/536 are so perfect for the OFT)
Hi werinshades,
Many of my problematic DMR/NXDN OFT are local and I use many outdoor antennas.
These are very important in my monitoring so my ultimate question to Upman is:
- Does Uniden is planning to work on fixing this issue ? (and is it fixable) ?
If the answer is negative, I will simply get rid of the SDS100-SDS200 and return to my two 536 and get another 436
With all my respect, i did not pay that kind of money just to get two nice color displays; I want the audio (first).
And I will not waste my time trying to find the appropriate settings for each individual sites while the 436/536 are doing it perfectly without missing a single transmission.
People often say "conventional" to mean non-trunking. that would be the same as NXDN one frequency.Can I get some clarification on programming as it is noted on here being programmed as:
One Frequency NXDN and Conventional NXDN.
I use the ARC software and the options are
Conventional
NXDN
NXDN One Frequency.
There is not a Conventional NXDN option.
I am trying to monitor the Dean Transportation system in Lansing, MI and have tried NXDN and NSDN One frequency and not heard any voice.
The only way I have heard voice is doing close call.
