milcom_chaser
- Joined
- Jul 4, 2010
- Messages
- 982
...I surely took that into consideration and ran with a few different rubber ducky antennas, one cut for the UHF band and the other a Radio Shack 800 MHz antenna obviously not cut for 450-470 reception (although it does a pretty good job everywhere).
As far as I can see now the issue appears to be the fact that the control channel was an active part of the programming. With the control channel removed and the system still being scanned as a trunked system, performance is far better and the flashing S is only present when there is a signal present on the system and voice is not being decoded. When voice is being decoded the T flashes. From what I understand from Don's posts, aside that there's no control channel programmed, this is relatively normal for the display.
So that pesky control channel, which one would have thought would be a must for tracking a trunked radio system, appears to be the detriment instead. Who knew?![]()
