NXDN Upgrade for BCD436HP and BCD536HP Now Available!
I tried function,sytem and it went right back to scanning with no save option.
This system has me stumped.. Seems two listings for same area,Loc #1 fixed and Loc#2 mobile
CC is 452.325 RAN-4 for sure strong signal on location #1 fixed which is what I'm working on.
So far I have these 6 freqs I'm trying on location #1.
Not very active system yet here as fairly new license active on this location.
Newer Baycom license WQFF501 is one I'm working on.
451.225
451.575
452.325 CC
453.000
461.125
462.025
ULS License - Industrial/Business Pool, Trunked License - WQFF501 - BayComm, Inc.
ULS License - Industrial/Business Pool, Trunked License - WPVS931 - DILORENZO, ERMANNO
sibbley
Nazareth, Pennsylvania
If it went right to scan then no LCN's were found. I've been down that road before. Sometimes you just have to wait for the systems to gain more activity. I had one system that took almost a year till I could get the LCN's due to lack of activity. That system only had 3 frequencies.
u2brent
OAMPT
KRWDPAXKRS1
451.225
451.575
452.325 CC
453.000
461.125
462.025
The System and site your scanning is in the DB.
https://www.radioreference.com/apps/db/?sid=8108
https://wiki.radioreference.com/index.php/Fleetcall
If Programmed as NXDN Trunked with the known channel#'s listed below in a site, you'll hear plenty if within range.
Only the 5 channels are confirmed in use. The others are not currently part of the trunked system at that site.
https://wiki.radioreference.com/index.php/Fleetcall_Frequencies_and_Site_Research
(FC04) Theodore (Rising Sun)/Cecil MD WQFF501/WPVS931/WQTX740
451.225000 37 RAN=4 CC
451.575000 0 RAN=
452.325000 213 RAN=4 CC
453.000000 321 RAN=4
461.125000 0 RAN=
461.200000 0 RAN=
461.675000 0 RAN=
461.900000 0 RAN=
462.025000 0 RAN=
462.537500 0 RAN=
462.737500 0 RAN=
463.456200 693 RAN=4
463.725000 736 RAN=4
464.175000 0 RAN=
464.400000 0 RAN=
464.637500 0 RAN=
Ok U2 will take your word on that,I was going by the FCC license info in addition to RR database.
No offense but many times RR database is out of date..
Thanks.
u2brent
OAMPT
KRWDPAXKRS1
I've can confirm it to be correct.. I submitted it.
Program these frequencies Just as shown into a site in a nxdn trunk system and enable ID search
451.225 CH# 37 RAN=4
452.325 CH# 213 RAN=4
453.0 CH# 321 RAN=4
463.4562 CH# 693 RAN=4
463.725 CH# 736 RAN=4
If you PM me your real email address I can send you the whole system as an hpd file which can be used with arc536 until Sentinel is updated. :)
03msc
RF is RF
The Natural State
Thanks.
Hopefully when you find that "out of date" information you then use the "submit" button to submit it since the data in the RR database is only as good as what is submitted by members like you and I...otherwise, the only offense is our own...
u2brent
OAMPT
KRWDPAXKRS1
nothing is out of date with regard to site 4, been listening on the 436 since the upgrade, and on DSD+ since at least 09-03-2017. note the history tab
https://www.radioreference.com/apps/db/?sid=8108&tab=reports
23000 Towing has been the only active TG this evening.
If you see NX4 then it's working.
Daytime is much busier.
can't vouch for the other sites, can only go by what's posted.
Lots of frequencies with a 0 for a CH.# and no RAN's posted in the DB.
Folks have their homework...:lol:
Voyager
Ok started LCN search and so far got 3 of 6 LCN on early short search.
Where do I find my results? Backed out and started all over again.
The results, if any are found, are stored in the channel in the Site. You can edit the site (then frequency) to see if an LCN was found.
DennisKink
Pickle City,IL.
Question about LCN finder. If you have to wait on an active channel that might take days, does the finder start up where it left off if you turn off your scanner and then turn it back on later?
scan-pa
RRDB Admin
Lebanon, Pa.
No, you will have to restart the session.
Sent from my SM-G935V using Tapatalk
Voyager
WOW! I read a post that told of a guy who ran LCN for over a year to finally get that last number.He didn't do that with batteries lol.
Odds are that last LCN's frequency was not active for a year. Maybe they finally added the listed channel.
Just because someone is licensed for a frequency does not mean it's in use.
Maybe a precursor to LCN Finder use should be monitoring the frequencies to see which ones are active, then program those only into the trunk them run LCN Finder.
LCN Finder will never find the LCN for a frequency that is not used.
jonwienke
More Info Coming Soon!
VA
No "maybe" about it. License info gives you a better idea to look, but it's common to see DMR on a freq licensed for NXDN or P25, and vice versa, or frequencies licensed but not used.
WX4JCW
Stow, Ohio
Some systems are easy some are a real pain
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
