Where is the fun in that.
Use your dollars for a subscription on RR.
You will need that to import from there.
Not sure if you can import to ARC536, I'm not familiar with that program.
Proscan is my preferred option.
You can even control your radio remotely from a Proscan window.
It is real easy, once you get the hang of it.
For each area, I create a favorites list.
An example being
FO1 Aviation
FO2 Business
FO3 Amateur
FO4 Local Body
FO5 Marine
FO6 Other
FO7 Public Safety
FO8 Railways
Then import into those favorites from RR.
The RR database is not up to date for a lot of NZ, thats where you use the Wiki.
You can't import from the Wiki, but you can use the info to update or edit your program.
