Oconee Areawide Radio System
MTS2000des
5B2_BEE00 Czar
The XTS5000 has many more advantages over the 2500 with three of the major things being it is more durable, has more zones and talkgroups than the 2500, plus the 5000 uses the same accessory connector as the MTS2000 & HT1000 which saves agencies the expense of replacing headsets or headset cables and other accessories that use the accessory connector. Our 800 MHz P25 Selection Committee found three or four weak points in the design of the 2500 that we felt would plague us with problems over time if that model radio was selected, so it was ruled out in the first round of evaluations.
The XTS2500 uses the same accessory connector and programming cables as the XTS5000, I know I own three of them. And no problems using my legacy Jedi accessories including my NMN6193C speaker mike, BDN6466 audio adapter, etc. with my 2500's, the programming cables and CPS are identical, I can even drag and drop codeplug data between the 2500 and 5000 (provided they are same RF bands) with ease.
Not sure what you mean about more channels and talkgroups, on the current HOST/DSP release of 15.00.02, the XTS25000 supports up to 840 channels/talkgroups per radio, more than enough for large metro wide area systems.
I will agree the 5000 is more durable, the immersion rated versions (R designator on the 5K, I on the 2500) are greater for the 5000. It's also more of a "brick" of a radio, and easier to add a UCM for encryption (the initial AN versions of the 2500 had limited encryption capability, but the current BN 8MEG version alleviated the limitations and in fact support all the available Astro 25 encryption options including multiple algorithms).
But the 2500 is a price point radio, and for light duty, non FD and PD use, it's a great alternative to the 5000 and IMO, overpriced APX line.
You'll have to give a full report on the TK-5410 and it's performance. My experience with the early (circa 2007) Japanese P25 radios (specifically the Icom IC-F70/F80) was disappointing. Poor audio, firmware bugs, and little to no factory support. Getting a simple DSP upgrade was an exercise in futility. I think Kenwood is a little ahead of them on this.
I recently evaluated and drive tested a NexEDGE conventional system for a government agency in Cobb county to replace their legacy wideband analog repeater. I was duly impressed with the digital performance on 12.5KHz, and the audio quality was superb. Not to mention, the price point of the subscriber radios was comparable to a quality analog radio, and not insanely high. I give NexEDGE a glowing recommendation for non-public safety use.
b7spectra
EMS Dispatcher
Cobb County, GA
Always makes me wonder why radio's such as HT220's, MT500's, HT600's, HT1000's, MT/MTS/MTX radio's last so long when the new equipment is only given about a 5 year life span. As someone who carried a radio in both public safety (EMS) and private sector (working in building maintenance), my radio in the private sector was subject to more abuse than my EMS radio did. Water, dirt, constant abuse up to and including using it as a hammer, never stopped my old series HT440. Now, in today's world, Big M and others want you to keep your portable in a hardened case so not to let even sunlight hit it. I don't want to say "I don't understand", because I do. If a company rates a radio for 10 years, you will push it to get 12 out of it, where if you rate a radio for only 5 years, you push it to get 6 and then the company says you HAVE to get new equipment as it is no longer under warranty. From a stock holders view, it makes plenty of sense. $$$ talks and the bull hockey walks!
Radio durability
Hey b7spectra, It's planned obsolescence at it's best! However, one thing we may want to check too was WHERE those HT220's, MT500's and HT440's were made. I don't know for a fact, but my guess is they were Made in America. I'll see if I can pull some of these out of the display cases in the Fire Museum and take a look.
XTS5000 vs. XTS2500
Hey MTS200des,
I was recalling from memory on my statements in my post about the findings of our P25 Selection Committee related to the different brands and models of radios we tried out because I did not have any of the evaluation results in front of me since I do not participate in this forum from the office. Anything I do on this site is on my on time and on my personal computer, so please keep this in mind and that it was almost three years ago that the committee performed the tests. I may be wrong, but I am almost certain the version of the XTS2500 that we looked at over three years ago only had 512 talkgroups compared to a lot more on the XTS5000 at that time. If the 2500 only had 512 talkgroups at that time then I'm sure Motorola has changed this since then because they have been marketing it to public safety agencies even though you and I both know this is not a public safety grade radio (I believe KSU and Southern Poly PD officers use the XTS2500 as do many other agencies). Again, our selection committee ruled out the 2500 for several reasons with the two main reasons being we did not feel it was durable enough and we felt the audio quality wasn't quite as good as the other models. I'm not going to take the time to outline all of these findings, but I highly encourage any agency considering this model radio to submit an open records request to our purchasing department and request a copy of the committee's findings to review before they make a purchase. Of course, the findings may not be applicable to present day versions of the radios since vendors have issued firmware and software upgrades since that time. I hear Motorola is considering adding MotoTRBO capabilities to some of their P25 products to enhance interoperability because many of their customers have public works, schools, etc. on MotoTRBO and public safety on P25. Sound interesting?
Regarding the TK-5410, again, I like it a lot. There are a couple of physical changes that I would like to see made, but overall I think it is a very good radio, especially for the price. I personally think the remote speaker mic pushes out a much louder audio than the XTS5000 and EFJ 5100. The TK-5410 will not do SmartNet, but you and I both know that really isn't a factor any more, at least not for much longer. Anyway, if you'd like to come by my office I would be more than willing to show it to you. I do not have the programming software or system key for the demo 5410, so I have to go to the County to have any changes made and I may be trying to get some of the scan settings changed later this week.
On your tests of the NEXEDGE equipment on the UHF System, you said the audio quality was superb, but would you rate the audio quality of NEXEDGE better than P25? I tested some NXDN equipment in VHF a few weeks ago and I was extremely impressed with the coverage and audio quality. I understand the City of Canton PD and McDuffie County SO really like theirs. I personally think NEXEDGE/NXDN could be a very viable alternative to P25 for public safety and it looks like that is definitely happening. I understand the NEXEDGE portable radio is less than $600 on State Contract, so an agency can't go wrong with the durability and capabilities of this radio at that price.
MTS2000des
5B2_BEE00 Czar
Hey MTS200des,
the XTS2500 got upgraded when the BN version was introduced. Not sure if you demo'ed an AN version or what the time frame was, but the 8MEG controller version supports the exact same HOST version as the XTS5000/XTL5000. The code is IDENTICAL, so all the capability of channel capacity, system capacity, etc is also identical to the 5000. There are some minor radio OS differences (for example the lack of a conventional user RF power output slaved to a control or menu as is possible on the XTS/XTL5000) but otherwise the same radio operating software (ROS).
the HARDWARE is quite different, the 5000 having a separate RF board and VOCON board, enclosed in a reinforced frame. The 2500 has a uniboard chassis, (not counting the display board or UCM board if equipped). This means if any failure in the controller occurs or the RF sections, the entire radio is pretty much replaced.
Both radios can and always have had the capability to use legacy Jedi/Cosmo audio accessories, such as speaker microphone and headsets. The XTS2500 does require a small plastic reinforcement piece to support the accessory connector, which is included with the radio, and just snaps on the rear and makes the radio thicker in that section of the housing so the accessory connector won't snap off. The public safety RSM's are different, due to the differences in the housing and the required mating RF switch adapter. Jedi RSM's are not compatible with either XTS as the Jedi series used an integrated RF antenna select switch in the connector itself (and it was a common trouble point, I've probably replaced over 100 in my time).
The radios are aimed at different markets. The 2500 is a light duty radio designed for EMS, public works, etc. I carry one for the size factor and prefer it to the 5000 only because I carry enough crap. :lol:
On the NXDN drive tests we conducted, we had the repeater setup for dual mode operation, so we could switch between analog 12.5KHz compandered audio and NXDN. NXDN was superior, especially in fringe areas or when heavy interference was present (we did have an offending carrier from a nearby system at times). As far as audio, it is hands down better than the IMBE systems I listen to including Cobb and Atlanta. Even when users overdrive the audio, the AGC is much better at taming it and not distorting the input to the vocoder. It also appears to have a better frequency response curve but that could be attributed to the subscriber radios themselves. We did not test the 6.25KHz mode as the repeater was not setup for it as was delivered. But overall, I am duly impressed.
The price point on the radios is indeed impressive and competitive as is the cost of the repeaters. And with the flexibility to buy other vendors subscriber radios (Icom, Tait, Ritron, etc) one isn't locked into a single vendor in the future should they wish to expand.
Abb0
USA
...Of course, some people have told me manufacturers are being creative in finding ways in locking/blocking out radios made by the other vendors from working on their P25 systems or at least making the radios made by other vendors appear to be inferior by not having the exact same features and functions of a radio they produced...
Replace "manufacturers" with Motorola ;-)
kb2crk
arnoldsville ga.
i was told by a local fire chief in Greene county GA that they will be 800mhz digital by july. the system has been approved for at least Greene. Athens Clarke county is still 800mhz trunking even thought they were supposed to be digital last year. Oglethorpe county GA will be narrow banding their existing system just before the deadline. the sheriffs dept is the only group not already there. (repeater is still wide band. EMS and fire are simplex and went narrow with the last license renewal.) it will be very interesting to see how the 800mhz system works with all the hills and valleys in Greene county.
nunyax
Walton County, GA
From Greene County, Nov. 2009:
County receives $3 million grant for radio system
And note they were already alluding to encryption.
kb2crk
arnoldsville ga.
as of right now Morgan county in on board and going ahead at the same time. siloam VFD will be keeping its VHF repeater (it is already narrow band) and using VHF hi radios in their apparatus alongside the 800mhz for interoperability along i-20 in Taliaferro for the rescue truck. the vhf paging system will still be in use for the fire depts. i am not sure where Oconee stands with it right now but Oglethorpe was talking about going to VHF lo but decided to stay put on vhf hi. i guess the next time Union Point pulls me over for a tag light out i wont be able to hear them...lol
  • Haha
Reactions: RRR
Greene County 800 MHz P25
What, only a total of $5 million in Greene County to switch from VHF analog to 800 MHz P25? Either they are not buying very many radios and only putting up a couple of tower sites or something else is going on down there related to funding. Did they not have a SPLOST to help with this project?
nunyax
Walton County, GA
ha ha, a vendor guarantee a phase I migration to phase II using existing hardware for both subscriber units and infrastructure? Wish I saved some of the initial Astro 25 literature I got in late 2002. This was promised and now it's clear Motorola is about to kick the entire Astro 25 platform (at least in reference to subscriber radios such as the XTS and XTL series) into history and is going back on it's word to offer HOST/DSP or VOCON upgrades to support phase II..
Okay, I'm thoroughly confused. From the article linked in this thread:
http://forums.radioreference.com/co...nnounces-shipping-plans-p25-phase-2-tdma.html
"For existing ASTRO 25 customers, the end-to-end upgrade to P25 Phase 2 — including base stations, subscriber units and consoles — can be achieved via software upgrades, according to Brenda Herold, Motorola Solutions’ vice president of subscribers and infrastructure."
I wonder if this will apply to the XTL/XTS line?
kb2crk
arnoldsville ga.
i do not remember the number but i believe it was a good deal higher than 5 mil.
Oconee hired an outside contractor to secure grants.
http://www.oconeecounty.com/OCWeb2009/Minutes/2011/2-8-11M.pdf
b7spectra
EMS Dispatcher
Cobb County, GA
With the Hundreds of Millions of dollars being fed to Motorola for all of these new TRS's, I wonder how much it would have cost to have the entire State of Georgia to be a TRS? A state wide TRS and every jurisdiction has access to it.
MTS2000des
5B2_BEE00 Czar
It will never make economic sense. Back in the 1990s the state put out an RFP for a statewide 800 system and the figure was roughly between 250-400 million. There just isn't the budget for it especially now.
kb2crk
arnoldsville ga.
ButchGone
Ringgold, Georgia
In watching these recent Georgia threads I wonder this: what if Georgia and all the counties upgraded the state wide VHF system with something like nexedge? County/city agency repeaters could update with 12.5KHz analog and digital AMBE voice capability. With narrowband more VHF frequencies come open for agencies. That means the tried and true 154.905/154.935/155.370 system gets more split channels, plus the nationally recognized V-tacs, etc and you have all the interop channels you need. You have easy simplex operation. Equipment would be much more affordable for local governments. Everybody can upgrade and expand system to new standards. Plus, VHF works a hell of a lot better in a place like Georgia than 800Mhz. You won't need expensive computer controlling systems and expensive software updates. And your not fighting interference issues with cellular 800MHz systems. I'm sure it would save a helluva lot of money too.
BG..
