Sownman
I had a strange occurance last night I'm hoping someone can explain. I was about 3 miles from BUR and got a hit on the approach frequency 134.20000, then on the tower 118.70000. My signal on those is usually pretty poor and hard to understand and this was as well. I just happened to turn off my car ignition during a transmission and as soon as ignition went off the PsR500 picked up a loud rapid chirp, maybe 5 beeps per second. On the scanner display the signal strengh flashed on and off in time with the beeping.
When I turned the car back on the scanner beeping stopped. I monitored the frequency for several minutes and every time I got degradation of reception and beeping with car engine off and improved reception with no beeps when car engine was turned on.
I can certainly understand the chance for car ignition interferance but how could engine running improve scanner reception ? What if anything could I try to get rid of this. I tried attenuating the frequency but it just made everything go away.
Steve
Steve
