We're all in guess mode at this point, but I think people are reading a bit more into the press release than it said.
Many many years ago, a friend of mine designed and built something similar to this. It used a custom PIC type processor, two line LCD display, and controlled his Icom R7100. I think he later added support for Optocom via a PRO-2006.
It's a GREAT concept, and I'm glad to see it come online commercially so people like me that don't have hundreds of hours to spend on developing custom hardware/software can play too.
The press release mentioned 6000 channels. My vision of how this device works is that you program it as normal (like the 396) but add GPS coordinates to systems, then set a radius on each one. If you're within range (as determined by a NEMA GPS feed into the scanner), the system is switched on. As you leave range, it changes systems accordingly.
I suppose someday there could be some partnership with XM or Sirus, where it automagically downloads current data from some source on the fly as you drive across country, but I don't think someday is Spring 2006.
Preloaded systems will likely be similar to those that came with the 396... good enough to get you going, but most hardcore users will replace all of them with their own configurations.
Questions I have are:
Is GPS a Uniden plug in part, or can I use a standard GPS w/NEMA output?
Why oh why didn't you make a remote head option? $250 ham rigs have it, PLEASE consider this in a future model. We don't all drive Suburban's with consoles in the middle.
How about DTMF decode to compliment the two tone decode for tone out?
As it turns out, I'm not in the market for a mobile scanner at this time, but I'm very much in the market for a base. Thought this might be it, but it's not revolutionary enough for me to spend the $$$. I'll likely buy a 330 handheld to use as a base (since I computer control it anyway), freeing up my 396 for portable use.
Off topic: My 396 has been continuously powered on and recording traffic on a large CDF system for three weeks now (there are still a few tone outs that I haven't figured out yet). Works great.
