BCD325P2/BCD996P2: OFT not displaying talkgroups or radio IDs
Pr999
Allegan County, Michigan
I can't seem to get my scanner to display talkgroups of RIDs with OFT. I don't know what I'm doing wrong but I have the site and the two talkgroups programmed in along with the conventional frequency on a separate bank.
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
The setting needs to be enabled via the Settings menu as is described in the easier to read manual linked here:
Disp. Unit ID allows you see the unit ID of the radio currently transmitting on Motorola, EDACS, and APCO P25 systems.
Scroll to 'Disp. Unit ID' and press E/yes.
Scroll to On or Off and press E/yes to save and exit.
Pr999
No, not that. I also do have that already enabled, but the problem is nothing is showing up after I programmed an OFT. Do I need to get rid of the conv. channel I programmed? What do I do?
