hoser147
Im still into the learnin curve, But I thought the 96 did great and this blows it away on reception and tracking. In time..............Hoser
An easy way for SMV users to listen to more than feed would be for them to open up one feed in Windows Media Player (the default player), then change the selected player to "Web Player", and then click on another they want to listen to. The second feed will be opened in a Flash player that will run in a separate browser window.mtindor said:So, is there any way to provide multiple feeds and have users be able to monitor them simultaneously?
scangwinnett said:An easy way for SMV users to listen to more than feed would be for them to open up one feed in Windows Media Player (the default player), then change the selected player to "Web Player", and then click on another they want to listen to. The second feed will be opened in a Flash player that will run in a separate browser window.
Yep ;-)mtindor said:Thanks. I'll have to get with you about getting what is needed for the additional feed. Will send you an email (I'm assuming you're Gordon heh).
Yes.FPO703 said:Will WinAmp work for all of the feeds on this system?
jasonk said:Hey there Online Scanner Listeners. Alot of people don't realize how to listen to multiple feeds at Scan MiamiValley. If you look just below the actual feed area you will see a link to Click here to select your player. This gives you 5 options. You can actually listen to 5 Feeds at Once ..... Not that I have ever done this (grin) ......So make sure you have Media Player, Winamp, Itunes, and Real Player installed and enjoy.
Also - the Northwest Ohio Feed and the SW Cuyahoga County Feed both Stream Alpha tags. Make sure you use Winamp or Realplayer to listen to these. The actual Talkgroup description will appear in the player when the radio has traffic. Makes it nice to follow a particular incident.
digitalanalog said:Thanks Gordon for the setup info, everything went very very easy.
Now streaming Columbiana County
Some of the stuff scanning.
Columbiana PD,Fire,EMS
Columbiana County Sheriff
New Waterford PD
East Palestine PD
Salem PD,Fire
St.Claire Township PD
Perry Township PD
Sebring PD
East Liverpool PD
Wellsville PD
Lisbon PD
Salinesville PD
Leetonia PD,Fire
and more to be programmed.................
running 24 / 7
Enjoy...........
