One Repeater?
N
N_Jay
Guest
X1536 said:
Is it possible to only have one repeater for a PD? Has anyone ever heard of it?
Yes. If they only have one channel pair, and don't have too many officers.
Remember LOTS of PDs only have 5 to 15 officers.
Thorny41587
Holland, OH
What do you mean by one channel pair? Yes, it's a small city. Four watts just doesn't seem like a lot of power to me. For the portables to get out to the one repeater... however it is about 1,000 feet above the ground. (water tower)
NeFire242
Nebraska
There's quite a few depts on simplex too!
Well yeah if it's 1,000 ft in the air, talk about good coverage. Power doesn't always mean much, it's how high you get that antenna.
mdulrich
Van Wert, Ohio
I'm sorry, but a 1,000' water tower? Where is this at, I have got to see it.
Repeaters usually aren't much higher than a couple hundred feet.
Mike
Sonar
SoCal
I'm guessing the water tower is on a hill that gets the antenna up to an elevation of 1000'. Not a 1000' water tower literally.
mdulrich
Van Wert, Ohio
He asked about Bowling Green, Ohio FD in another post and the only things that are 1,000' in the air in that part of Ohio are TV antenna towers and airplanes.
Mike
N
N_Jay
Guest
Mike
Bowling Green is at about 700 ft, so it only takes a 300 foot tower to get to 1000 ft AMSL
mdulrich
Van Wert, Ohio
The statement was "however it is about 1,000 feet above the ground. (water tower)."
Mike
nexus
Mississippi
What's simplex? Without a repeater?
X1536, First YES a lot of police departments, fire departments, EMS agencies, and just about anyone else who uses radios can have just one repeater. Multiple repeaters are used in a trunking system usually.
But agencies who don't use trunking will be whats called "conventional" And that can be either a repeater OR simplex.
A repeater is a device that takes the signal on one frequency (an input) and automatically rebroadcasts it through an antenna at a high altitude and usually with much more power onto another completely different frequency (an output). When you're talking about repeaters the term "channel pair" will come into play meaning the input and output frequencies for the repeater.
Simplex = Single frequency, nothing is repeated
Duplex = Two frequencies (channel pair), used in a repeater.
N
N_Jay
Guest
Mike
Well, then I guess some people have trouble judging height.:roll:
rescuecomm
Travelers Rest, SC
My local PD uses a UHF repeater for dispatch comms. All the city services were on VHF spread out on 4 repeaters. The PD went to UHF to allow comms with the local county sheriff and two of the neighboring counties. The officers carry a UHF portable, but the cars have VHF and UHF mobile radios. The third neighboring county still uses VHF. The UHF ended up as an add on instead of a replacement, but gave improved interop capabilities. The Detective branch also has a digital talkgroup on the state wide 800 system. The single dispatch repeater is able to carry 99% of the comms. They do switch to the old 155 VHF repeater for informal comms.
twolf816
Bastrop, LA
and alot of agencies with 2 repeated channels and 2 or 3 simplex talk arounds....as in the case here.....personally i think the whole parish (county for non-louisianans) should get a trunking system for public safety...but im not in charge
