No the computer and scanner are plugged into separate outlets across the room from each other - tho by necessity the computer, printer, and related equipment share the same surge protecttor and outlet.
But I tried making feed from different computer (plugged in by itself in living room) and scanner in different rooms like kitchen and still have hum.
If your house wiring is of that of the older "2 wire" then most likely your computer is using the coax shield as a ground (if your antenna is grounded) and the current is flowing through the audio cable.
I solved the problem for my feed by making a dedicated, (grounded) outlet to a ground rod outside and grounding "everything" to that common ground. I attempted using a isolater in the past but found another ground path via the neutral on the scanner power cable. I know a lot of people frown upon the configuration because per NEC code my secondary ground rod should be tied (bonded) to the house's primary utility ground. However with just one outlet and nothing but the feed computer and scanner plugged in theres no easy soultion.
Everything meaning = Coax shield bonded to audio cable shield, audio cable shield to computer chassis screw, computer chassis effectively grounded by 3rd wire at outlet.
The only danger is that if lightning finds it way into the house it could choose a path via any electrical wire to this outlet then through everything connected and to ground. Therorectically since the resistance of the ground wire is less than the coax then it should follow the ground at the outlet or back (the way its supposed to) to the switchbox, since there, the neutral is bonded to the utility ground rod.
Using a isolater is the legit way to go but then you leave the insulation in a tandy made device's transformer coil as the only block in a "lightning strike finding your coax as ground" situation.
5 years ago I found out with the help of a nearby lightning strike, the expense of a scanner, motherboard, audio cable, and melted isolation transformer, thankfully the antenna only suffered superfical "melting" at the connector > mast/ground.
