j_mar
Hi All!
I'm having the same issue as this thread:
OP25 Audio Slow and Choppy
I'm using a brand new RPI 4b (1gig) and new NooElec NESDR smart v4 running raspbian buster. I am trying to listen to the North Fulton Regional Radio System (NFRRSA). My first setup had audio that sounded terrible, so I tried the solution from the original thread by getting a brand new class 10 SD card and wrote a new raspbian buster image (didn't copy the old one in case of user errors). Got everything set back up using John's Tech Blog instructions and am having the same problem.
My audio sounds like this while running op25 through VNC. I've got the speaker hooked up directly via cable to the pi and not bluetooth. The audio plays perfectly with the same setup over VNC while in gqrx or youtube. My gut tells me I'm doing something wrong on my end or that there's some driver issue going on but I don't have the knowledge to troubleshoot it further.
My setup does lock onto the control channel and pull in audio. Here's my err log and trunk file (I've tried both CQPSK and C4FM).
The command to launch op25 looks like this: ./rx.py --args 'rtl' -N 'LNA:47' -S 2500000 -x 2 -f 771.98125e6 -o 17e3 -T trunk.tsv -V -2 -U 2> stderr-stream0.2
The only other thing I noticed is that htop shows a lot of instances of rx.py running but I'm not sure if that's normal or something funky going on.
Thanks in advance for any help as I'm stumped!
