So I had the opportunity to do my own coverage testing on the new system. While I will say for Fire it will be much better than low band, there are definitely dead spots and areas with no bars but still a receivable signal. There is going to be some talk in problems as well, especially interior. And while I know the system is designed for on the street portable coverage, that was even lacking in areas. Since I know a lot of the dead spots with the current EDACS and VHF systems, I used it as a comparison. While Fire is still going to use the UHF 16 channel plan for interior ops (which they should), they should be ok for the most part. Command is normally run from the rear of the vehicle on a mobile and portable operations are relayed to command via UHF simplex. Good to go there. But my testing was mostly based on portable coverage.
I’d have to say that I’m a bit disappointed for Police and EMS. As you know, for PD it’s our lifeline. Most calls involve going inside a building to investigate an alarm or deal with a domestic situation. Portable coverage is not going to be any better than EDACS or VHF in certain areas, and in some worse. I can tell you Woodbury is going to suffer with Arden not on the air. For EMS, most members use portables. I know certain agencies that have their own dispatch like New Windsor, Woodbury, Cornwall, Warwick, etc. have VHF systems that will actually provide better coverage than the new trunked. Cornwall always had issues along 9W going up the mountain, 32 going south from 107 and up on Mineral Springs on EDACS. Cornwall EMS’s VHF system provides coverage in all these areas, on portable, from Snake Hill (where the County does not have a site). I can’t say the same about the new trunked system. So they may have to walk outside on a BLS call turned ALS to radio for a medic because their APX goes OOS. Or walk back to their vehicle on an MVA...oh wait, they only have portables. Same for PD...hate to be fighting with someone inside a residence and get that booooop that is the loudest thing in the world at that moment. For Woodbury as an example, go test inside the Commons where Arden blankets and I’ll bet Schunnemunk doesn’t get in as well. I actually made a comment on this forum about having Bull Hill as a backup...now that you don’t have Arden, what’s the next plan ? Or is there one ? Same with Monroe...PD has their repeater up on Bald Hill...no County site there and no Arden. Hopefully Southfields will get up that far with Schunnemunk as your primary. But in building ?
I will also point out that they are gong to have to allow agencies to utilize both simulcast sites. On 17K/300 I was getting blasted by Beacon on south and Cronomer on North on a Unication G5, so I could be on either one and good to go. But let’s take Cornwall again as an example...if you just put them on south, there are actually areas that Cronomer covers better than Beacon, especially along the Route 32 area going south and with the loss of Arden, they are going to need it. I routinely roamed over to North along that stretch until I was able to pick up Schunnemunk down towards Woodbury. Without north, I would have been OOS. I actually programmed each system separately as well in the G5 to test where I may have better coverage on North vs South. Town of Goshen as an example...plenty of areas where the Goshen site will cover on North but others where I’m looking at Schunnemunk and getting blasted on South. Same with Town of Montgomery. Several areas where Beacon and Schunnemunk on south will provide much better coverage than the site actually in Montgomery on North. Since the County wasn’t able to license certain frequencies at all sites and had to split it, you have to allow roaming. Greenville and Wallkill used to call 911 on the VHF Priority channel on Beacon instead of Graham because talk in was better. Arden EDACS slams into Wallkill in certain areas. See my point.
But I’m just a guy on a forum and the powers that be are the decision makers. Maybe someone will take my advice.
