Out of range error for certain p25 system sites/simulcast
jrock71984
I have tried programming certain p25 systems that have multiple sites and programmed the sites that are in my area and should be picked up by my Unication g5 the systems that I am having issues with are the metro25/mta mrss and the Connecticut land mobile radio network I have checked and the sites I have programmed according to radio reference cover my area and the g5 should be picking it up I have programmed other p25 systems with no issues what am I doing wrong
Hit_Factor
Saint Joseph, MI
For me, new system out of range means I made a mistake programming. I might have entered a decimal value when it should have been hex. Check WACN and sysid, then rfss/site entries.
Using the wildcards for sites usually helps troubleshooting, if it works with the wildcard, then check the site entries.
IAmSixNine
Dallas, TX
Since you imported and not manually typed in info, you should go back and verify site RFSS, ID an frequencies. Making sure the Site ID and RFSS info is in HEX and accurate.
K9KLC
Southwest, IL
I agree, I would double check this. I know I tried to do a CSV import from RR and that didn't work. Importing directly thru the CPS from RR has worked however but I'd still double check maybe a frequency (control channel) hasn't been added if you can.
