Good to know, thanks.
So with digital seems the whole playing field changes. With analog, I guess it's much more straightforward to design a radio receiver, and trunking was as complicated as it got.
Trunking does not complicate it per-se, trunking just dynamically assigns channels out of a pool of available frequencies. It allows for a more efficient use of limited resources. With analogue trunking, you are still just listening to analogue transmissions. Even analogue simulcast systems(trunking or conventional) will sound ok, as long as you are with in the engineered coverage area.
With multicast, it challenges the already complex DSP, decoding, and error detection/correction a radio has to do.
I believe you are referring to simulcast, the difficulty scanners have with LSM(Motorola simulcast) is that rather than use C4FM modulation, like a conventional, or multicast trunk system uses, LSM uses CQPSK instead. To properly decode CQPSK you need a receiver that output I&Q data, rather than using a discriminator tap that is just fine for C4FM, heck you can even decode DMR, NXDN and even Provoice formats using a simple discriminator tapped scanner. CQPSK a is a different modulation, and a different wave form, and does not decode very well using a discriminator tapped receiver.
Still, your cell phone is a digital radio, and the sound quality (relatively speaking)
And uses a channel MUCH wider than a LMR voice channel.
and signal reliability are there,
Because it is in the telco providers best interests to provide the coverage their consumers demand. Where as first responders get that ever the politicians decide to fund... While we all want the Cadillac system, that gives 100% portable on belt, interior of building coverage 100% of the time, the reality is that most governments cannot afford to provide it. So usually they buy the 95% mobile, primary highway coverage 95% of the time Volkswagen Beetle system. They then blame the lack of portable on belt coverage on the vendor, and end up, in the end, paying for the 'extra' infrastructure to give them the coverage they actually wanted in the first place.
and doesn't require "professional equipment" costing thousands.
But your phone is not designed to take the beating that a public safety user will impart on their LMR equipment.
How does it manage to handle signals that come from multiple towers?
It doesn't, it listens to one sector of a cell site at a time. And when certain criteria are met, the call will be handed off to the adjacent site.
Seems to handle it a lot better, wouldn't you say?
See above
Now that I replied to this post, I will take some time to read the documents you linked to.
Do realize that you can
NOT compare public safety LMR to that cell phone you are carrying in your pocket. To completely different technologies, for different missions, funded in completely different ways.
Sent from my iPad using Tapatalk
