scanthewaves
Whenever I listen to a P25 system audio seems garbled with too much modulation, makes me wonder if the units hear it the same I do on their radios?
Which system?Whenever I listen to a P25 system audio seems garbled with too much modulation, makes me wonder if the units hear it the same I do on their radios?
And what radio? LOLWhich system?
Which system?
Garbled transmissions are quite common when trying to monitor a Simulcast system with a scanner that does not handle that well.
436hpAnd what radio? LOL
436hpWhat kind of scanner are you using?
Okay. And what city are you in?436hp
Kingsville TX I just tried a Digital AGC tweak and it improved a bit, I've been told on the Texas forum that the system isn't simulcast but now I'm not so sure.Okay. And what city are you in?
Sorry, is that Kleburg County or Nueces County? The database is showing two counties for Kingsville. I don't know if there's a township named Kingsville too, or if maybe it could be on the county line?Kingsville TX I just tried a Digital AGC tweak and it improved a bit, I've been told on the Texas forum that the system isn't simulcast but now I'm not so sure.
The Kingsville system, in Kleberg County, is simulcast.Kingsville TX I just tried a Digital AGC tweak and it improved a bit, I've been told on the Texas forum that the system isn't simulcast but now I'm not so sure.
Sorry it's Kleberg CountySorry, is that Kleburg County or Nueces County? The database is showing two counties for Kingsville. I don't know if there's a township named Kingsville too, or if maybe it could be on the county line?
So does that mean that if that frequency is left out it will affect proper reception and yes I"m one of the contributers to that Port A thread, I was there and I have been able to monitor Port A on that P25 system, it too must be simulcast as it seemed garbled as well. I don't understand how that newer system can be better with only 3 towers VS. the existing 5, I would think some areas might be affected by the range of these towers.The Kingsville system, in Kleberg County, is simulcast.
View attachment 130090![]()
Kleberg County Public Services Trunking System, Kingsville, Texas
Kleberg County Public Services Trunking System Profilewww.radioreference.com
There only two sites for transmitters, but it is simulcast.
Looking at the details on the for the Coastal Bend Regional Interoperability system, it appears that the database (in RR) does not correctly identify two of the sites.
Coastal Bend Regional Interoperability Network Trunking System, Varies, Texas
Coastal Bend Regional Interoperability Network Trunking System Profilewww.radioreference.com
Site 2, Flour Bluff, is not listed correctly. It only shows one frequency, listed on the system's page, is 853.425. There are other frequencies at that location, on license WPWX340.
However, looking at Site 5, Shoreline, it shows as licensed on KNNY532. If you take a look at that license, 8 of the 15 frequencies listed for Shoreline are also licensed at Flour Bluff.
What is complicating the matter on the Coastal Bend system is that the current system used for the Corpus Christi area, for the Four County Coastal Bend Interoperational System, which is EDACS, is being phased out, transitioning operations to the newer system. Once that transition is complete, and someone in the area can correctly map out exactly how the sites are set up, then it may well be that other sites are simulcast as well.
There have been a couple of threads in the Texas forum on talkgroup status for Port Aransas as well s a Corpus Christi talkgroup. Once the changeover is complete (I'm not in that part of the state), and things settle down, hopefully the corrected information can be gathered & submitted to the database.
I thought the control channel would tell it the frequency to tune to?If your missing a freq, it will affect reception. If its a voice channel, and it's missing, you will never hear any voice thats on that freq.
With a Harris trunking system, all voice channels are also potential control channels as well. Harris systems are designed to rotate control channels frequently. You need to enter the voice channels just because they are considered control channels as well.While the 436 does do control channel only, as listed in the manual, it does also say, " With Motorola trunking frequencies, you do not have to program voice channel frequencies. " .
Is system in question Motorola?
