P25RX-II P25RX-II Firmware Updates / Testing
btt
Jew lover
Banned
Wa State
More output for 154.175 MHz in Benton County, Wa
2023-01-14 14:44:31,op=28, TONE_OUT_EVT:, 660.00, 13, 688.25, 14
2023-01-14 15:16:42,op=28, TONE_OUT_EVT:, 849.00, 19, 752.50, 16
2023-01-14 15:17:13,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 15:21:20,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-14 15:29:34,op=28, TONE_OUT_EVT:, 849.00, 19, 914.25, 21
2023-01-14 15:29:39,op=28, TONE_OUT_EVT:, 849.00, 19, 598.00, 11
2023-01-14 16:14:31,op=28, TONE_OUT_EVT:, 660.00, 13, 806.25, 18
2023-01-14 16:56:19,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-14 16:56:51,op=28, TONE_OUT_EVT:, 660.00, 13, 806.25, 18
2023-01-14 17:00:31,op=28, TONE_OUT_EVT:, 849.00, 19, 598.00, 11
2023-01-14 17:00:36,op=28, TONE_OUT_EVT:, 849.00, 19, 914.25, 21
2023-01-14 17:17:41,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-14 17:21:34,op=28, TONE_OUT_EVT:, 566.00, 10, 932.00, 22
2023-01-14 17:54:01,op=28, TONE_OUT_EVT:, 880.50, 20, 1684.75, 45
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
Todd,
Can it be set up so it looks back to the paging frequency every second or so by using the priority level settings? Also, will it "look" back from P25 to analog NBFM then return to P25?
btt
Jew lover
Banned
Wa State
Todd,
Please correct me if I'm not understanding this correctly. I don't think this will work because the two-tone decoder is working on the analog audio output. When decoding an analog channel, there is no new information coming in from a digital P25 channel and vice versa. I may not be understanding your question, so please elaborate further if that did not answer your question.
btt
Jew lover
Banned
Wa State
some more output:
2023-01-14 18:12:12,op=28, TONE_OUT_EVT:, 849.00, 19, 806.25, 18
2023-01-14 18:16:35,op=28, TONE_OUT_EVT:, 849.00, 19, 914.25, 21
2023-01-14 18:36:21,op=28, TONE_OUT_EVT:, 598.00, 11, 932.00, 22
2023-01-14 18:49:28,op=28, TONE_OUT_EVT:, 1797.25, 48, 344.25, 3
2023-01-14 19:05:22,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 19:12:39,op=28, TONE_OUT_EVT:, 660.00, 13, 806.25, 18
2023-01-14 19:15:16,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 19:15:19,op=28, TONE_OUT_EVT:, 660.00, 13, 688.25, 14
2023-01-14 19:16:50,op=28, TONE_OUT_EVT:, 880.50, 20, 1684.75, 45
2023-01-14 19:19:37,op=28, TONE_OUT_EVT:, 1219.00, 31, 1184.50, 30
2023-01-14 19:35:48,op=28, TONE_OUT_EVT:, 660.00, 13, 806.25, 18
2023-01-14 19:35:51,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 19:52:43,op=28, TONE_OUT_EVT:, 1797.25, 48, 849.00, 19
2023-01-14 19:54:00,op=28, TONE_OUT_EVT:, 660.00, 13, 688.25, 14
2023-01-14 20:08:17,op=28, TONE_OUT_EVT:, 849.00, 19, 435.25, 6
2023-01-14 20:21:32,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 20:21:36,op=28, TONE_OUT_EVT:, 660.00, 13, 688.25, 14
2023-01-14 20:31:32,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 20:31:36,op=28, TONE_OUT_EVT:, 660.00, 13, 849.00, 19
2023-01-14 20:31:39,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-14 20:32:44,op=28, TONE_OUT_EVT:, 849.00, 19, 914.25, 21
2023-01-14 20:42:18,op=28, TONE_OUT_EVT:, 660.00, 13, 806.25, 18
2023-01-14 20:42:22,op=28, TONE_OUT_EVT:, 660.00, 13, 688.25, 14
2023-01-14 20:42:25,op=28, TONE_OUT_EVT:, 880.50, 20, 688.25, 14
2023-01-14 20:48:42,op=28, TONE_OUT_EVT:, 849.00, 19, 806.25, 18
2023-01-14 20:52:18,op=28, TONE_OUT_EVT:, 849.00, 19, 752.50, 16
2023-01-14 21:02:01,op=28, TONE_OUT_EVT:, 1347.75, 35, 344.25, 3
2023-01-14 21:02:06,op=28, TONE_OUT_EVT:, 1797.25, 48, 344.25, 3
2023-01-14 21:02:10,op=28, TONE_OUT_EVT:, 344.25, 3, 849.00, 19
2023-01-14 21:26:38,op=28, TONE_OUT_EVT:, 660.00, 13, 806.25, 18
2023-01-14 21:26:42,op=28, TONE_OUT_EVT:, 660.00, 13, 849.00, 19
2023-01-14 21:52:52,op=28, TONE_OUT_EVT:, 849.00, 19, 566.00, 10
2023-01-14 21:54:43,op=28, TONE_OUT_EVT:, 849.00, 19, 752.50, 16
2023-01-14 21:55:37,op=28, TONE_OUT_EVT:, 849.00, 19, 566.00, 10
2023-01-14 22:06:01,op=28, TONE_OUT_EVT:, 880.50, 20, 1684.75, 45
2023-01-14 22:20:37,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 22:44:54,op=28, TONE_OUT_EVT:, 2461.50, 62, 344.25, 3
2023-01-14 22:44:57,op=28, TONE_OUT_EVT:, 344.25, 3, 1055.00, 26
2023-01-14 22:49:23,op=28, TONE_OUT_EVT:, 849.00, 19, 752.50, 16
2023-01-14 22:51:23,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-14 23:21:47,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-14 23:30:26,op=28, TONE_OUT_EVT:, 880.50, 20, 1684.75, 45
2023-01-14 23:40:49,op=28, TONE_OUT_EVT:, 880.50, 20, 660.00, 13
2023-01-15 00:10:28,op=28, TONE_OUT_EVT:, 849.00, 19, 752.50, 16
2023-01-15 00:28:29,op=28, TONE_OUT_EVT:, 849.00, 19, 598.00, 11
2023-01-15 00:38:51,op=28, TONE_OUT_EVT:, 849.00, 19, 752.50, 16
2023-01-15 00:40:07,op=28, TONE_OUT_EVT:, 1797.25, 48, 660.00, 13
2023-01-15 00:57:41,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-15 01:04:55,op=28, TONE_OUT_EVT:, 660.00, 13, 688.25, 14
2023-01-15 01:30:55,op=28, TONE_OUT_EVT:, 849.00, 19, 914.25, 21
2023-01-15 01:31:00,op=28, TONE_OUT_EVT:, 849.00, 19, 598.00, 11
2023-01-15 01:45:46,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
2023-01-15 01:45:49,op=28, TONE_OUT_EVT:, 660.00, 13, 598.00, 11
2023-01-15 01:47:46,op=28, TONE_OUT_EVT:, 660.00, 13, 719.00, 15
2023-01-15 01:47:52,op=28, TONE_OUT_EVT:, 660.00, 13, 752.50, 16
goldmyne99
During the testing of the P25 two tone decode on the MicroP25RX, I had my P25 system's Paging TG set at a high priority level and the TG Priority Int feature works well. It should also work well on the RX-II on a system's P25 TGs.
As for Priority Int across other frequencies/systems/modes, that is a different operational question as the radio only has one receiver.
vince48
Central Valley, CA.
wondering if the group can recommend a antenna for my mixed mode montering. I monitor 900mhz trunk system, 750mhz trunk system and a host of 150mhz/400mhz PD and Fire.
Note this needs to be an inside antenna. Realizing that one antenna will not be perfect for all frequencies I use, but a "nice" compromice
maus92
The OP
There are so many variables to consider with an inside antenna. My rec is to stick with the telescopic antenna that came with the radio as there will be no cable loss. Do you have access to an attic? How about a window? I've seen some people erect an all-band antenna on a stand that could double as a coat rack - not sure how much it actually improved their signal, but if they think it did.... Remember in general that UHF and above is "better" in penetrating buildings than VHF. If you decide you need something better than stock, go with something you can stick on a window or window sill, and keep the coax cable as short as possible.
K9DAK
Wauconda, IL
I had pretty good results with an old VHF/UHF 300-ohm twin-lead J-Pole I made years ago, binder clipped to the light fixture chain over our kitchen table. I was not successful, however, at convincing my wife to let me keep it there, so as maus92 said, I went back to the telescoping antenna that came with it, adjusted to be 1/4-wave at 155 Mhz.
vince48
Central Valley, CA.
thanks guy's for teh suggestion. I was using the stock antenna, but it will not stay upright. It falls backward due to the little screw will not stay tighten.
It did give fairly good reception, but it jsut won't stay in postion.
maus92
The OP
It did give fairly good reception, but it jsut won't stay in position.
A tiny drop of silicone sealant or similar applied to the outside of the nut adjacent to the sma threads after tightening will keep it in place and can be easily peeled off. Or just wrap a rubber band around the antenna and case with just enough tension, lol.
maus92
The OP
I would *love* to see Jason / Trunking Recorder and Bluetail get together to provide a calls recording interface similar to what has been done with SDRTrunk. I've been testing Trunking Recorder as the primary listening interface in my building via the LAN. It combines a SmartZone system decoded with Unitrunker / Airspy with a Phase 2 system decoded by SDRT. Selected talk groups are recorded and retained on the network, and then played by via a web browser. Works great.
Edit: I'm wondering if I pointed the BT audio directory to the one used by SDRT would accomplish the same thing, as what I *think* happens is Trunking Recorder processes mp3s from the SDRT audio directory, creates a db entry and moves them to its audio directory. Hmm...
btt
Jew lover
Banned
Wa State
btt
Jew lover
Banned
Wa State
I use an antenna simiilar to this (different model than what I use) with an NMO base mounted on a ~3ft tall metallic structure. It works great for monitoring everything from 150 to 900. I find it to be an excellent antenna for general sub-ghz monitoring.
vince48
Central Valley, CA.
This is what I use indoors to scan 150, 172, 450, 770, 850 bands on a single receiver.
Todd
this would work, what NMO base are you using with it?
btt
Jew lover
Banned
Wa State
Todd
Had to take one apart and find the model. The antenna I'm using is Tram model# 1182, and NMO mag-mount base with SMA connector.
Antenna
Example NMO mag-mount base:
maus92
The OP
I was looking at the docs for Rdio Scanner - it does not support Unitrunker 2 natively, so it's not going to work for me. Additionally, I don't think that the P25RXII is the right radio to use for my purposes because it processes calls serially. Not a big deal for a slow system, but I routinely have 2-3 or more talk groups in use simultaneously on each system that I need to capture. I currently have 4 virtual cables configured on the SmartZone system, and 4 channels available on SDRTrunk. Oh well, thought it might work.
btt
Jew lover
Banned
Wa State
Yes, the P25RX-II processes a single, analog-filtered channel of 12.5 kHz bandwidth. It also doesn't require a PC to receive. I find this makes much more sense than to force a $3k computer get warm by processing 800 channels when you only need 4. They definitely are different approaches.
