P500 Evaluation
N7YUO
Kearns, UT
I got permission to post some of this programming so more members could look at it and maybe we could figure out what is wrong with it.
This is Utah P500 programming from a non-Utahn.
The first thing I notice is the lack of hits.
I also notice he has a lot of car to car TG's.
He has Southern Utah UHP TG's when scanning SL Simul.
What's missing that should be here:
UHP SL Dispatch
SL REgional
Landing Zones 1 & 2
Unified Police, and many others in SL County.
Fire & EMS TG's.
I do not know how long he scanned SL SIMO and only got 21 hits.
First Leg of Vacation 2011
Scanlist 9 SL Simo
853.087500__a sl simul__ok
853.112500__C SL SIMUL__ok
853.512500__a sl simul__ok
Trunking Tables
Low___High___Off____Base_______Remarks
440___559____440____851.0250___ok
0_____719____0______851.0125___ok
720___759____0______848.0000___not needed
815___831____0______846.6250___not needed
958___958____958____868.9750___not needed
961___1022___0______843.0000___not needed
Multi Site Mode: Stationary____________(If you have only one site, why use MM?
Check all CCs in every scan-mode pass Y
Priority Settings
N Priority enabled
N Quick post-priority unmute
Y TGRPs interrupted
0 CONV to check each pass
Miscellaneous Settings
Y Enable Hit Counts
Y TGRPs in disabled SLs = Locked Out
Y Show CC Info on TGRP display
TGID Format: Native
Motorola Trunking
Subaudible Start Delay: 150
Endtone Pattern: 2B2B
Endtone Threshold: 80
Talk Group Objects in Scanlist 9
Alpha Tag___________Type____TGID___Pri__LO__Dly___Hits___Actual Use
SLAKE SIMO________Group___Wildc___N___N____Y___20____Wildcard
SLAKE SIMO_________Privt___Wildc___N___N____Y___0_____Wildcard
UHP 3 Utah Count____Group___4512____N___N____Y___0_____UHP UTAH C2C
UHP Special Oper____Group___4608____N___N____Y___0_____UHP SP OPS 1
UHP Special Oper____Group___4640____N___N____Y___0_____UHP SP OPS 2
UHP Inspection C____Group___4768____N___N____Y___0_____UHP INSP C2C
UHP Utah County____Group___19744___N___N____Y___0_____UHP UT CO DISP
UHP 4 Salt Lake_____Group___19776___N___N____Y___0_____UHP SLCoServ
Midvale Police 3_____Group___21792___N___N____Y___0_____MIDVALE PD 3
Sandy Police 2______Group___21984___N___N____Y___0_____SANDY PD 2
Sandy Fire Car t_____Group___22016___N___N____Y___0_____SANDY FD C2C
Sandy Police________Group___22048___N___N____Y___0_____SANDY PD 3
South Salt Lake_____Group___22144___N___N____Y___0_____S SALT LAKE C2C
Midvale Police D_____Group___23040___N___N____Y___0_____COTTONWOOD PD
Sandy Police Dis____Group___23104___N___N____Y___0_____SANDY PD DISP
South Salt Lake_____Group___23200___N___N____Y___1_____SSL PD Disp
Sandy Police 6______Group___25280___N___N____Y___0_____SANDY PD 6
South Salt Lake_____Group___26176___N___N____Y___0_____S SALT LAKE INV
UHP Washington ___Group___30464___N___N____Y___0_____UHP Virgin
UHP Cedar City (____Group___49664___N___N____Y___0_____UHP CEDAR
UHP Virgin River____Group___49696___N___N____Y___0_____UHP VIRGIN
Midvale Police 4____Group___58144___N___N____Y___0_____MIDVALE PD 4
N7YUO
Kearns, UT
I just hooked up the programming cable to upload this P500 to my scanner.
The first thing I see is this message:
One or more object IDs are duplicated (or are not valid) and must be fixed
When I load the program, It shows these scanlists active:
14, 16, 17, 19, 20. Scanlists 16 & 20 flash on and off simultaneously.
So, I turn off 14, 17, & 19. It now says Nothing Enabled! So 16 and 20 are on, but empty.
I turn on scanlist 9, SL Simul. I get steady calls, mostly on wildcard.
N7YUO
Kearns, UT
Looking at scanlist 5 for Washington County,
These are his System Frequencies:
Washington County
System Frequencies
852.662500 st george
852.037500 ST GEORGE
853.637500 TOQUERVILLE
853.475000 UTAH HILL
851.187500 no CC
851.600000 no CC
851.837500 no CC
852.275000 no CC
853.187500 no CC
853.612500 no CC
851.825000 francis pk
852.125000 no CC
852.937500 black crook
853.412500 no CC
853.662500 laketown
853.912500 LAKETOWN, DANIELS
859.437500 no CC
859.487500 no CC
Recommend these four:
kf7yn
West Jordan, UT
I would delete the group wildcard on SL Simo.
Also, Midvale PD was absorbed by Unified PD so 58144 (digital) is gone,
23040 is now exclusively Cottonwood Heights PD
21792 is no longer Midvale Ch 3.
Highpockets
Toms River, New Jersey
I attached the last file that Brent sent me of his programming, not sure if it will help anyone out there. I'll leave it attached for a few days and then remove it. I guess some info is outdated.
pmstewart
Ogden, UT.
Jon,
Is there a particular reason why we cannot submit to have those 3 talkgroups changed to reflect their current status in the DB?
Paul
kf7yn
West Jordan, UT
To my surprise, my Trunker files show 2 of the old Midvale TGs have been active, 58144 as recently as 02/06/2012 and 21792 was last logged 02/17/2012. Although they no longer belong to Midvale, someone is using them. Maybe they have been reassigned. We need to figure out who the new users are before submitting new info.
Junior1970
Western Utah
Is it possible that:
a) Midvale is using the non digital TG for city related business or
b) UPD is using Midvale's old TG's both 58144 and 21792 for PD business now.
Anything is possible. I will have to pay attention more now for I was just about to remove them from my Win96 file.
Thanks for the heads up........................
pmstewart
Ogden, UT.
Way to go Jon!! Your always on top of the current info and we will always be grateful to you for your contributions!!
Paul
