Passport Conventional?
Southtown800
Banned
Manhattan, New York, 10005
i live in CT where there is a huge passport LTR company and my local Ambulance company...hunters ambulace went LTR Passport but i can track them conventioanlly on a scanner....
If i input this Frequency in a GP300 can i still track in conventionally?
cg
Connecticut
you can hear as well with the GP300 as you can with the scanner. The system is not able to be trunktracked with any single scanner or radio except a Passport radio that has a serial number registered on the system. There are several channels that you will have to monitor to hear the ems units however you will also hear many other users.
chris
Southtown800
Banned
so if i put in the Freq i can track them conventionally??
because when i monitor 461.7875 all i get is the Hunters Dispatch and some local units...but what you are saying is that i will hear other users come across that channel in their talk group?
You are probably listening to their home channel. In LTR each radio and has a home channel or frequency.
462.950 Home Channel or LCN 10
462.9000 Home Channel or LCN 20
If 10 is the home channel for the ambulance company then the radio will attempt to use the 10 channel first if it is busy it will use another channel. When the repeaters are not busy that is the most likely time the home channel will be used and you will be able to listen conventional. When the LTR system is very busy you will miss a lot of communications because the radios will use whatever repeater is avalaible.
Southtown800
Banned
it's hard to follow but i am getting it...it is missing talk groups basically??.....but i think i will stick it in at this time because their is not alot of activity for hunters...thanks alot everyone
cg
Connecticut
The Passport LTR system is a networked system. When a unit drives from one area to another they affiliate (or electronically sign on) to the site in that area. If there is no unit signed on within a specific site, the talkgroup will not be broadcast in that area.
If you are not hearing other users traffic, then it is not likely that you are monitoring the trunked system. It is possible that there is one frequency for local ops and they use the trunked system for units that travel out of the area.
As I am not sure where in CT you are, I cannot suggest any specific freqs but if you go to the RR database, I have submitted the Marcus system info that I have accumulated. The Durham site is where I have heard thier talkgroups before.
http://www.radioreference.com/modules.php?name=TRSDB&sid=4117
chris
