Passware Kit Forensic
kendrik578
Live Audio Administrator
Greensboro, NC
OK, so i came across this program called Passware Kit Forensic
and supposedly it can decrypt various programs and files including TrueCrypt volumes. So, whats your take on it? Has anyone ever tested this? Can it REALY decrypt TrueCrypt volumes? I don't know if i can believe this.
kendrik578
Greensboro, NC
Apparently the Truecrypt volume has to be mounted. So it's useless. http://www.lostpassword.com/hdd-decryption.htm\
I use individual portable volumes. You won't decrypt that.
Looks like the pirate bay has a copy in portable. I'll have to give it a shot on Truecrypt.
So your saying that No it can not decrypt a TrueCrypt volume?
I tried that Passware from the PB and it couldn't even decrypt a simple word file.
poltergeisty
Truth is a force of nature
RLG, Fly heading 053, intercept 315 DVV
I just tested the Truecrypt portion and it in fact works at brute forcing and finding the password. I used something simple and set it to the right size though. Now Truecrypt allows you to use so-called keyfiles so this attack won't work on truecrypt protected volumes using keyfiles. I always use keyfiles from DVD's
questnz
Truecrypt would take months and months of continuous running of any software to decrypt depends on strength of encryption. I tried Passware on small 256 MB USB stick encrypted with MS Bitlocker and for sure it found the key in less than 10 minutes. Hate to thing how much would take to scan 1 TB hard Disk?!. On Truecrypt AES256 encrypted volume it said it will take 7 month+ to scan ??!!! No results guarantee.
Passware will REMOVE most passwords from files rather than DECRYPT them. It has its uses.
kendrik578
Greensboro, NC
What enc method did you use?
I usually use AES-Twofish-Serpent for my volume's.
