crippledchicken
Those two use different frequency steps don't they the 4800 and the 9600? Just curious, where does your scanner show NX4 system if, you have the sds 100 or 200. I just wanted to check my sds 200.
You can easily tell by listening to the raw control channel or voice channel signal in analog FM mode if it is 4800 or 9600 baud. Post a recording and I can tell you.For example, my scanner shows we have an NX4 system which is 4800, not an NX9 9600 system.
There are no 6.25 or 3.125 kHz steps on the 800 MHz band in the US (yet).Those two use different frequency steps don't they the 4800 and the 9600?
I own both the SDS 100 & 200.Those two use different frequency steps don't they the 4800 and the 9600? Just curious, where does your scanner show NX4 system if, you have the sds 100 or 200. I just wanted to check my sds 200.
I tend to agree that it isn't an MDT channel - at least not for now. The units are pretty much running all the stuff that they would be running on an MDT over the air. I am at a loss to come up with more than a WAG as to what it is for. It could be for a future MDT system, geolocation, or just for future scalability. I guess we will see.I am in my fifth day of searching for the unknown LCN for 858 MHz on site 1. I no longer think it is an MDT link as i never hear a reply which would not be a weak signal like all signals so far have been.
I for sure have been hearing both sides of the PBFD.I tend to agree that it isn't an MDT channel - at least not for now. The units are pretty much running all the stuff that they would be running on an MDT over the air. I am at a loss to come up with more than a WAG as to what it is for. It could be for a future MDT system, geolocation, or just for future scalability. I guess we will see.
I am pretty sure I also heard BOTH sides of the PBFD system today on TG 108! Wasn't close to the scanner so not 100% sure. But will try and nail that down.
Thanks for that confirmation. I am starting to think that they PBFD will not migrate to the 800 MHz system. However, they will probably have some radios that are on the 800 MHz system - I would think that the Commanders will have an 800 MHz radio in their vehicles for interoperability reasons. And they probably have a few 800 MHz capable portables as well. That may relate to some UID's that I have logged, but don't hear any traffic on.I for sure have been hearing both sides of the PBFD.
Those are for frequency coordination purposes and usually don't reflect real life radio coverage.The FCC Site said each Site has a 21.7-mile radius coverage.
That's odd... I was listening to the same incident, and I heard both Dispatch and well as ground units on 154.220.Also, Friday night a house fire on Harper Street had 7 or 8 trucks and 2 full crews working it. I only heard the PBFD Dispatch on the old 154.220. I also never heard any “Fire Ground chatter” during this entire event even on 154.220.
I was hoping to confirm 107 as an PBFD Fire Ground TG, but not this time.
I agree, the following is what I overheard many years ago and they were not talking to me. So, let me know if I am even close to getting it right.Those are for frequency coordination purposes and usually don't reflect real life radio coverage.
Please disregard, I have a separate post for you.
Were you also listening to the NEW system?That's odd... I was listening to the same incident, and I heard both Dispatch and well as ground units on 154.220.
I don't remember how the point radius for mobile areas of operations is calculated but if it was "real" it wouldn't be a perfect circle with the same radius in all directions. Sometimes they are a county or state.I agree, the following is what I overheard many years ago and they were not talking to me. So, let me know if I am even close to getting it right.
I believe they called the FCC maps a “Theorical Isotropic RF Projection Map”. They use the following data:
No, this was on their regular channel... I have that avoided on the PD's system,Were you also listening to the NEW system?
Is your new Yagi still mounted horizontally instead of vertically?I'm thinking my location is keeping me from receiving PB Public Safety system. I cleared user data and formatted the sd card. I gained from 3 to 5 signal bars. But, my RSSIs are still high and so are the Digital Error numbers. I'm assuming that's why I can't understand what they are saying most of the time. RSSI numbers vary between 92 and 98 on average. Digital Error ranges between 7 and 24 to 27 or so. With 5 signal bars those are about the only reasons I can think of for the garbled voices?
