Possible new Norman TGs plus updates
woodyrr
Midwest City, OK
fireant said:
Woody,
Yes Cedar Country is definitely fire department it is a volunteer fire department. My uncle use to be on their department as their training officer. Highly possible that they may have a 800 radio to talk to Lexington or others for mutual aid.
fireant
Thanks. The Lexington Fire talkgroup just came active and there was a CW ID so I presume that since CW IDs are, for lack of a better word, "supressed" on trunked systems, the Lexington talkgroup is a link to a conventional repeater.
EDIT: Well, DUH, It says so right in the database! Being in Texas must have damaged my brain.
Here in MWC, I seem to get better reception of the "new" norman system than I did with the "old" one, although the old DPS Norman site 25 is still pretty marginal.
plaws
E Hawkesbury Twp, ON
woodyrr said:
Disregard -- I see that 48304 is Lexington --
Is there a place around there called Cedar Country? If there is, 48304 identified as Cedar Country 3XX. Don't know if it is fire or police, but my bet would be fire.
One of the many FDs on the "Lexington" channel. A VFD in the eastern part of Cleveland Co. This is a patch to the 152.6600 repeater. Don't exactly have a good handle on who does what, but believe Lexington may dispatch them.
Someday, I'll put together a list of the Cleveland Co FDs and who dispatches what.
woodyrr said:
EDIT: 55120 Sounds like EMSTAT to Norman ER patient reports
Yep. I assume this is what used to be called "EMSSTAT 2". Showed up in the DB long before the cut-over.
Gilligan
Hagerstown, MD
plaws said:
Site 25 was and still is working.
The old Norman (two-site) system is Site 40.
Maybe I'm missing something here. Shouldn't Site 25 be in the DB then w/ the .9875 freqs ? Is it acting like a simulcast or just serving as another Norman tower in a different area of the city?
woodyrr
Midwest City, OK
That’s one of the (many) things that really discombobulated me when I returned from Dallas. I naturally assumed that the DPS Norman site would be incorporated into the new DPS / City of Norman site, but as I was tooling through Norman on my way home, my scanner was catching a control channel on both sites. When I got home, I locked on to the DPS Norman control channel, which was identifying as site 25. When I went to the database to find out what site 25 was, I didn’t find anything, which led to the first of my many post Dallas posts that are more reminiscent of the ravings of an escapee from an insane asylum than a reasoned observer of radio systems.
It is not a simulcast of the Norman system and I plan to leave it active in my radio until they decommission it as it is carrying the AR and some AM stuff as well as Noble traffic that I have monitored at least. They sure could use those five frequencies on site 8 imho.
A couple of other TGIDs to watch are:
53552 Noble tried to contact Norman RH with a patient report without success.
13744 I didn’t get a good lock on it but it acted encrypted.
plaws
Site 25 staus quo
Near as I can tell, Site 25 is operating exactly as it was before the cut-over. What the plan is, I don't know (clearly!), but I bet there is more to come.
plaws
Just had that TG pop up. P25 ENC all right.
Lots more P25 around, particularly around 15-16xxx. Not all ENC.
Edit: and again at about 2030 Monday.
plaws
Westwood
I'm going to go out on another limb and say:
  • 29072 - Westwood Golf Course Maintenance (was D WESTWOOD on the old list)
plaws
Updated list of ID'd TGs from Site 40
  • 27568 - Noble Fire
  • 27600 - Noble PD
  • 29040 - "Norman Park Maintenance"??
  • 30128 - "Norman Waste Water"??
  • 30384 - EMSSTAT 1 (admin traffic)
  • 48272 - Little Axe VFD (dispatched by Norman)
  • 48304 - Patch to Lexington Fire dispatch on 152.6600
  • 48624 - NPD Dispatch
  • 48656 - NPD Tac 1
  • 48688 - NPD Tac 2
  • 48720 - NPD Tac 3
  • 48752 - NPD Tac 4
  • 48880 - NFD Dispatch
  • 48912 - NFD Fire 1
  • 48944 - NFD Fire 2
  • 48976 - NFD Fire 3
  • 49008 - NFD Fire 4
  • 49040 - NFD Fire 5
  • 49072 - NFD Fire 6
  • 49104 - NFD Fire 7
  • 49136 - OUPD Dispatch
  • 49296 - OMNH security
  • 52176 - Norman Animal Control
  • 52496 - OU Parking Patrol
  • 52528 - OU CART (transit)
  • 53008 - School Police
  • 55120 - Norman Regional Hosp ED (EMSSTAT 2??)
  • 59312 - Norman Sanitation
  • 59344 - "Norman Meter Service" ("E MTR SVC")???
Confirmations for the ones with ??? please!!
woodyrr
Midwest City, OK
AAArrrggghhh!
I wish that I could be more helpful, but as of this morning, due to the change in seasons or the magnetic pull of the moon, I'm getting garbage ids. For instance, Moore PD 1 on 52448 and then a reply on 51360. I guess that I'm back to a frustrating search for a better antenna / coax combination :mad:. For the last three days it has worked so well.
I think that you very likely have 29072 correct. I'll bet I heard the same stuff that you did - about mowing between holes and sandtraps and such. You could probably send that one to the db powers that be and see what happens.
plaws
Search And Store
Put the ol' '396 into Search and Store mode, something I often forget it can do. Got the following hits off of Site 40:
  • 50672
  • 52480
  • 52592
  • 52800
  • 53264
  • 53376
  • 53392
  • 53552
  • 54512
  • 55168
  • 57424 - Norman LMA 7A
  • 63680
  • 64880 - Lawton PD School Security(!)
Interestingly, while all these are divisible by 16, not all are divisible by 32, the same issue reported on another thread.
woodyrr
Midwest City, OK
The bogus ids strike someone besides woodyrr!
plaws said:
Put the ol' '396 into Search and Store mode, something I often forget it can do. Got the following hits off of Site 40: ... Interestingly, while all these are divisible by 16, not all are divisible by 32, the same issue reported on another thread.
This is interesting. My 996 and 396 have been regularly having problems related some of these “talkgroups”.
Of those that you have listed, I have:
52480
53376
64880
as well as:
54800
62368
762917 and a few other 7xxxxx ids
locked out because for some reason the scanners often stop on those and sit with the squelch open. No voice is heard, just a squelch crash and static. I don’t know if they eventually clear and go back to searching since I reach up and hit the scan key as quick as I can, but I’ve never come home to find them locked up.
I have been passing it off to something here that is causing interference. Often, the open carrier is preceded by the detection of an emergency button activation, especially on 54800. I have been turning off and disconnecting things, the latest being my wireless router hoping that it might be the cause of the problem. I don’t remember having the problem before I set up the router, and I haven’t had one since I decommissioned it around noon.
Anyway, the reason that some may not be evenly divisible by 32 is that some of them are not “actual” talkgroups – if that makes any sense – for lack of a better way to describe them.
Thanks for the reminder on search and store. I'll try that.
Gilligan
Hagerstown, MD
I think the reason it's not evenly divisible by 32 is that the TGs start w/ +16. If you subtract 16 first, then it is evenly divisible by 32.
plaws
plaws said:
Good, we need your ears.
Yes. :D
The old Norman (two-site) system is Site 40. And those two new freqs that were assigned to Norman back in spring of last year were finally added, so 12 channels in all.
I haven't listened to 25 much, but probably should. The Site 40 seems to be advertising Site 25 as a neighbor, if I am correctly interpreting what Unitrunker is telling me.
I think Site 25 is colocated with the west half of what is now Site 40 at the Sarkeys Energy Center on OU's campus (tall, red, leaky building at Jenkins and Boyd). There is a note in the DB that Site 40 is a temporary label, so I gather there are further integration plans.
Now I see the problem - Site 25 was removed from the DB. It's still up and running as of this post, so the removal was a bit premature.
freqscout
Talkgroups on the state system are often spaced by 32, however they are designed and assigned to go in 16's. The state folks just jump double when assigning them.
As far as the 7XXXXX ID's. Woody have you done the firmware upgrade off the Uniden website. I used to get those all the time and then I did the update and do not get all of the birdie 700k id's. You can still get them when they are true private calls, it just filters them better. Plus the private calls will show up as 7XXXXX-7XXXXX. These are not too common around here, but are more so in Tulsa. They can be interesting in Tulsa.
This new Norman stuff is pretty fun. I wish I could hear the Norman site from my house. Opening up the database every day is like going to open new Christmas gifts from Scannerclaus.
plaws
And Noble (not much there) and MWC. And Pott County for that matter.
When will Edmond move? I assumed they'd wait for Norman to merge, but that's done as far as I can tell.
woodyrr
Midwest City, OK
freqscout said:
As far as the 7XXXXX ID's. Woody have you done the firmware upgrade off the Uniden website...
Boy, that sure got my hopes up, but everything is current. Fortunately, I get very, very, little that nonsense on the OKC site, it's just when I want to search Norman on the fringes of my reception, that everything gets all garbaged up. Thanks for the suggestion for sure.
plaws
Do you see that on UniTrunker? (assuming you are tapped) Or just on your radios? It doesn't take much to lose a bit here or there, but UniTrunker should reflect that in the "quality" display.
