No, I'm too chicken to tap a "precious" radio. Whether I tapped it with a soldering iron or tapped it with a sledge hammer the end result would likely be the same!plaws said:Do you see that on UniTrunker? (assuming you are tapped) Or just on your radios? It doesn't take much to lose a bit here or there, but UniTrunker should reflect that in the "quality" display.
woodyrr said:No, I'm too chicken to tap a "precious" radio. Whether I tapped it with a soldering iron or tapped it with a sledge hammer the end result would likely be the same!
woodyrr said:Have you seen any of the new MWC stuff on 40 or 25?
plaws said:52144 - Norman PD. Unk channel, unk if a patch.
Might be training.
plaws said:
- 57552 - LMA 7E.
LMA 7A is 57424, which leaves 3 other slots between there and LMA 7E.
B, C, D? That'd be my guess.
plaws said:49200 - OUPD - using it for ops at the sendoff for the 45th IB.
mam1081 said:Maybe tagged as "Special Events" ??
highrider8433 said:There is NO GAME TOMARROW Peter.
plaws said:Unless anyone has changes, I'll submit this to the DB (some of it is there)
Looks like we've got most of the active TGs.
