Steve08CVPI
- Joined
- Jul 28, 2017
- Messages
- 73
- Reaction score
- 7
Turn it on it powers up starts to scan then turns itself off then turns itself on repeat. Won’t just stay on. What gives?
SD card just went bad while the scanner was running?
I think Ubbe is talking about the 'Replay Options' settings. I'm not positive but I think that is set to 240 seconds by default so your 536 is always recording and erasing audio clips even if you never use the instant playback feature.Pretty sure record is off. I’ve never turned it on
As noted, the Replay feature records the past few transmissions received so that, if you missed something or wanted to confirm what you thought you heard, you could play it back.Pretty sure record is off. I’ve never turned it on
The clock has nothing to do with the SD card or its files. So probably something else that created a hickup.It was already off. Also the clock now stays programmed
