Hi all,
I am currently running the following:
tower mounted Sirio 100mhz+discone->stridsberg FM filter->mini-circuits ZFL-1000VH SMA connectors with heatsink->8 port mini circuits splitter. This setup is primarily for monitoring 136mhz to 940mhz; anything is bonus and not really used much (antenna is wrong for that anyway).
Overall, I'm fairly pleased with this setup. Question is, within a reasonable price range (<500 bucks used is ok) am I leaving any performance on the table with
regard to the amp? Is there something with a much better noise figure?
I do not generally see the pre-amp causing any overloading issues and my a/b comparisons do not suggest that the current level of gain is excessive.
So the question is, can I buy an amp that performs significantly better, with similar gain (I am driving 8 receivers) and SMA connectors, or should I be content with that I have. And yes I do realize that I might get a modest bump in performance from tower mounting the amp; that may happen eventually, but not immediately.
Thanks in Advance and 73.
