You have your location set as Saratoga County, NY. The trunked system listed for your county has two sites, both of which are labeled as 'simulcast'. The TRX-2 (or it's handheld sibling, the TRX-1) does not handle simulcast well. Simulcast distortion is very location driven. You might get lucky & have no problems. Or, you might be dead in the water receiving your home county system.
Never said i bought one.Posting for others looking to buy one.You have your location set as Saratoga County, NY. The trunked system listed for your county has two sites, both of which are labeled as 'simulcast'. The TRX-2 (or it's handheld sibling, the TRX-1) does not handle simulcast well. Simulcast distortion is very location driven. You might get lucky & have no problems. Or, you might be dead in the water receiving your home county system.
Understood. But that precaution still applies to anyone considering one of the TRX series scanners. Take a close look at your local systems before pulling the trigger on a purchase.Never said i bought one.Posting for others looking to buy one.
I always used whistler stuff and like it. But for a base unit a $40 dollar dongle and DSD+FL will do more for $40! That is assuming you have some kind of computer.
SDRTrunk and DSD+ work just fine with a cheap RTL-SDR dongle. I was a bit shocked, performance is actually better than my 996XT. They really can replace more conventional scanners in certain applications.A cheap $40 dongle will give terrible performance. These dongles don't have any filtering and shielding so performance will be limited to strong broadcast station reception and not much else. You need a more expensive dongle to get DSD+ to work properly.
Well that's really subjective. If you only want to listen to your town and surrounding town's law enforcement and fire departments a cheap $40 stick, 64GB or 128gb thumb drive to save recordings to, and an older business class computer do a fine job. Exactly the setup I've been running for almost a year straight nonstop now. I run mine in my basement with a Laird mag mount antenna stuck inside the basement window on the metal frame-works fine.A cheap $40 dongle will give terrible performance. These dongles don't have any filtering and shielding so performance will be limited to strong broadcast station reception and not much else. You need a more expensive dongle to get DSD+ to work properly.
