Pro-2006: Pro-2006 Question
HOGMOA
Shell Knob
I just received a Pro-2006 Scanner. On the back is a switch for 0db-10db Attenuation. Can anyone tell me what this means? Instead of seeing a button for Light on the front it has Dimmer. Is there a way to turn off the lighted display?
Thanks,
Frank
Xray
Don't think there is a way to turn off backlight without modding - And shouldn't the ATT switch be self explanatory ?
BC_Scan
Vancouver BC
it was for back in the day when we carried pagers intermod would occur on a desired receive fx, this would attempt to limit the overload of the receiver preventing you from hearing the desired signal, (today not so much) dependant where you like
im gonna say no not easily at least , not without intense modification (which we did on these back in the day) for a variety of different uses
kc2asb
NYC Area
Thanks,
Frank
The early Pro-2006's like yours (and mine) only had the dimmer switch for the light. On later models, it was changed to an on/off switch due to issues with the backlight failing.
fxdscon
¯\_(ツ)_/¯
Thanks,
Frank
Check this post:
rgchristy
Delco, PA
Enjoy!
  • More Pro 2005 Mods.txt
  • Pro 2006 Manual.pdf
  • PRO-2004-05-06 Computer Interface instructions 199203.pdf
  • Radio Shack Pro 2005 Mods.txt
  • Realistic-Pro-2006-discriminator-mod.pdf
  • Realistic-PRO-2006-Hardware-Modifications.pdf
KD4TO
The attenuation switch is normally left in the 0 position, the -10 position reduces the sensitivity of the receiver, perhaps useful in case of signal overload.
kc2asb
NYC Area
Exactly right. Even living in a high RF environment in a major metro area, I found the -10 position compromised the quality of too many signals and caused others to be missed altogether.
KD4TO
A few times I found the attenuation switch accidentally moved to the -10 position so I stuck a little piece of tape back there to keep the switch in the 0 position.
