PRO-2052
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Re: Scan Control
lgentle said:
I purchased the full version. OK, so what your saying about entering TG ID alpha tag's is I can only input tags for ID's that I want to listen to frequently? Sorry if I'm not getting this, but I'm still "new" to trunking. I'm used to my BCT7. Thanks again!
Those of us who own a Pro-2052 turned the scanner on for the first time once, :D then turned it on again, :eek: then a few more agains. :? And we were overwhelmed by "what to do next" :( . Mike is pointing you in the correct direction and will get you into tracking your large Smartnet system correctly :) . Both of you have the great ScanControl software 8) , he is not far from you so hopefully knows the system well :wink: .
I've attached a doc which you don't need for PC programming but it condenses the instructions in the manual for trunking into one page with step by step setup procedures. This may aid in understanding how and what the scanner is doing while you try to set it up correctly.
fmon
Eclipse, Virginia
Re: DOC file
lgentle said:
When I download this file, it is a .PHP file, not a .DOC.
Replace the php with doc. BTW, when I clicked on Download the doc opened in my browser.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Re: Scan Control
Yes, and keep in mind that it will only work while in trunk scan mode. While in search mode, Scan Control will not post the alpha IDs since it doesn't have them.
I've prepared a native SC .dat file that contains milair frequencies. However, don't expect to hear much on that short whip that comes with the scanner. You will need a good outdoor antenna and coax; that's another subject that I think should be handeled in the antennas forum on this board. Let's get you straightened out trunking first.
Since I can't attach a .dat file, send me a PMail to ka3jjz@netscape.com and the file is yours.
73s Mike
fmon
Eclipse, Virginia
Re: Scan Control
73s Mike
Mike, rename the file xxxx.dat.txt then submit. When he downloads he'll need to change it back to xxxx.dat
