Steve73
Southern Indiana
Yes. I used Win96 with no problems. I would start with checking the control channel frequencies. Also take a look in Win96 and see if the scan banks are enabled and RX mode is set to "MOT"
zachful91
Do you have a file I could use ?
I'm in Bloomington indiana
My bcd325p2 picks up fine.
But my pro-2096 picks nothing up other than conventional
Steve73
Southern Indiana
Nothing I have will work in your area sorry. Hopefully somebody in your area can help with that.
RMason
Mississippi / Colorado
Hi @zachful91 :
I'd start by confirming you are receiving the control channel. While scanning the P25 trunked system, press the "Man" button. If you are receiving the control channel, the display should show the frequency as well as the decode % and trunked system info (SystemID, WACN, tower info). See sample attached for my location. For SAFE-T, the SystemID / WACN should be HEX: 6BD / BEE00
What site do you have programmed? What control channel frequencies?
zachful91
Hi @zachful91 :
So should it look like this ?
(a) Site001 868.17500
(c) Dummy 1300.00000
(b) Site002 868.22500
(e) Dummy 13000.00000
(d) Site003 866.65000
w9sar
I'm in Bloomington too, and use a 2096 which works well. I could send you my file if you haven't found one yet.
w9sar
Yes I would like that. I'm not picking anything up p25.
For some reason, I can't attach the file here, so if you want to give me your email address, I'll send it that way
w9sar
You will need to right click on the file and Send to Compressed (zipped) folder to be able to attach it. Click to Attach files and Open the zipped folder.
Thanks!
RMason
Did you check to see if you are receiving the control channel as described in earlier post?
I suspect that the pro2096 might have drifted and is receiving off-frequency. If this Is the case, there is an internal variable resistor that would need to be adjusted.
