Pro 652 Programming
sambo300
Elizabethton,TN
Quickest and easiest way to program this scanner? I have the cable and a Win10 Pro PC. Thanks!
fxdscon
¯\_(ツ)_/¯
The quickest and easiest way would be for you to use the RR web programming service since you already have a premium subscription, and you would do that by using one of the supported 3rd party programming software packages:
That is assuming that what you want to listen to is available in the RR database.
sambo300
Elizabethton,TN
tvengr
Well Known Member
Baltimore County, MD
ARC 500 will work fine with that scanner. I use ARC500 Basic. The Pro version adds logging functions. I am going to check the database to see what you can monitor in your area.
tvengr
Well Known Member
The Pro-652 will receive almost all of the frequencies in Carter County. The one problem I see is that Elizabethton Fire Dispatch is DMR which the Pro-652 cannot decode.
151.07000 WQFQ855 BMCC 0
TG *
SL *
ELZBTN FDFire Dispatch DMR Fire Dispatch
sambo300
Elizabethton,TN
151.07000WQFQ855BMCC 0
TG *
SL *
ELZBTN FDFire DispatchDMRFire Dispatch
Sounds good.....got ARC500 installed. Now for the figuring out of RR database to ARC500 then to scanner. Sounds fun!
