Blackswan73
Off
I just picked up the Pro668 but it is missing the belt clip. Anyone know when I can order the belt clip? Whistler likely offers it but I do not have the part number. Suggestions?
I usually take the card out and use a card reader to update the card. Also if you are using Windows 8/8.1. There are procedures to follow to get the drivers to work.
Are RS 668 scanners still available at discount from RS clearance sales?
$249 if you can find one at a RS that is closing up, but you can find plenty to bid on Ebay auctions with most ending around $195-$215.
If you are using Windows 8 / 8.1 you probably will need to disable the mandatory requirement for driver signing that is imposed by default. Here is a link to a thread I started in the GRE / Whistler forum.
http://forums.radioreference.com/gre-scanners/298161-ws1080-win-8-8-1-driver-instructions.html
I have the software running great on 2 Windows 7 machines; just got a Windows 8 laptop, disabled driver signing as per link and have been trying for 2 days to get it running doing everything possible mentioned on RR and elsewhere. Program says the scanner is not connected. I'm lost. HELP please. Joe.
Thanks All. Got it working, I have to keep clicking OK in the popup that says scanner not found; after the 4th time it works!?!
From this thread, I'm not clear, can the 668 receive, or be upgraded to receive, P25 Phase 1?
