Pro-83 only static on all channels....
Caesar
Lexington, SC
I have a new Pro-83 however when i turn it on i get static (squelch) on all channels and it keeps it from scanning. i even put it on 146.535 and keyed up my base with 50watts and it still only had static so it has only static and is not recieveing. i have turned the squelch up but to no avail. i also 2+9+HOLD reset the scanner with no change.
I would just take it back but they have no more in the state. any thoughts?
SAR923
Try the NOAA weather channels. If you still get nothing, you have a bum unit and your only option is to return it. I knwo the 83 is now hard to find but better a working scanner than a dead, rare scanner.
Caesar
Lexington, SC
heh, same on weather and all but i took it apart and put it back together after making sure to ground out all the current and it now works like a champ! good deal..
thanks.
DT
GM
Pro-83 w/ cont. open squelch
I'm having the same static squelch problem on my Pro-83. By taking this unit apart and then putting it back together, should make it work like new again? I tried everything listed above with no avail. Any suggessions to make it work properly?
GM
Negative on the CTCSS. I'm ready to run this POS over with my car!
policefreak
Berlin, NJ
I've had exactly the same problem with my pro-99. Wondering if its a bad squelch pot inside the scanner. If so, how much you think it would cost to have it serviced at RS?
gremlin96
bad squelch pot, seems to be a problem with the rs units. I have a pro52 that the pot is bad. so far i have just replaced the pot with a restor. no adjustments doing it this way. this works till i can get to the store and find a replacement pot.
