Pro 95 with Win95 Programming software trunking question
als365
Santa Clara, CA
[Solved] - Pro 95 with Win95 Programming software trunking question
I have a question about using the Win95 programming software for the pro-95. I'm programming in a Motorola type II trunked system. On the window where you input all of your frequencies, to the right of that where you can assign alpha tags to your talk group ID's. Is there a way for it to program the scanner so you only search the talk groups that you programmed? As it is now, I programmed text ID's to the talk groups that I want to listen to, thinking that it would only scan the talk groups that I put in there, but it's still scanning all of them, displaying text id's for the ones that I assigned ID's to, and just displaying the talk group ID for he ones that I did not assign text id's to. Is there a way to program the talk group ID's with the text in the Win95 program to only scan the ID's that I assigned text ID's to? I know what a scan list is also, I’m just wondering if that can be done through the program. I'm having difficulty wording this question but I hope you all can understand what I’m asking. I hope I don’t have to put everything in there and lock out the ones I don’t want to use because the UCAN (Utah) system has a lot of TG’s.
Thanks,
Austin
als365
Santa Clara, CA
I'm assuming that by "closing" the bank, you mean select that check box that says closed. I thought it just turned the whole bank off to scanning.
KE5BCP
Analog Man
Lewisville, Texas
Nope... Mark is correct. To turn a bank off when scanning, simply press the number of that bank. Func 5 will change the bank from open to closed mode (for when you aren't able to use the software).
als365
Santa Clara, CA
Ah, between my post, and your response, i did what he said and it works perfectly. Thanks a bunch everyone
mkewman
Sacramento County, California
*takes a bow* ah elko nevada... i remember that place. they have a great local rock station there. my moving truck broke down there a few years ago while moving to california. beautiful area.
als365
Santa Clara, CA
"Nevada's best rock music, from the 80's, 90's, and today. Rock 93.7, KLKO" I make the 53 mile ambulance drive from Wells to Elko alot and need something to listen to besides the siren.
They just opened up a new station, 94.5, plays some rock type music i think, i don't listen to it much. Check it out if you come through one day.
ScanInyo
(INYO COUNTY)
Is it possible to change the welcome message on the PRO--95? with the WIN95 software?
loumaag
Silent Key - Aug 2014
Katy, TX
Nope, the Pro-95 (and 93) didn't come with that option.
tglendye
Blue Ridge Mountains, Shenandoah River- VA
A little off your original question, but you can also change from open/ closed by pressing function + 5.
