Pro 96 or Bearcat 296D
Voyager
RohnsRadio said:
Ok Guys and Gals,
Which one is better? and Why?
Rohn
KD4HCT
PRO-96 on digital.
Major points:
* It decodes better than the BC296D
* There are not audio quality settings to mess with
* It will decode multiple systems with no changing of audio settings. IOW: If there are multiple users on digital in the same band, the BC296D may not work with all of them at the same time.
Also, V-folders.
No digital card to create problems or loose connections.
As for the feature advantages of each unit, read this:
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=12413
The feature sets are something that YOU and ONLY YOU will be able to tell which best suits your needs.
In addition to all of this, it is very likely REBANDING READY! The BC296D will need an upgrade.
Joe M.
grosporina
North York, Ontario
I've seen talk that the Pro96 can't handle EDACS narrowband (whereas the BC296D can). Though if there's no EDACS narrowband systems you're interested in, that's irrelevant.
Dubbin
Findlay Ohio
Another topic that has already been beaten to death :roll: Must be something in the air today.
