Boatanchor
- Joined
- Jul 17, 2011
- Messages
- 991
OK guys, here's hoping that the right people read this and adjust future firmware to address this problem.
I can't confirm that this problem affects the GRE & Whistler units, although I have read comments from others that seem to point to at least the PSR800 being affected.
The problem is that the scanner will not stop on weak analogue (and presumably digital) signals when scanning, yet the same signals open the squelch when you manually select them.
Even if the squelch control is set to the very lowest position, before opening, the scanner skips over weak signals when scanning. Take the radio out of scan mode and manually select a channel and you can monitor without any squelch problems.
Others, please free to confirm on the other models.
