Will my old PRO96 pick up broadcasts on this ARMER system?
The short answer is: Maybe.Will my old PRO96 pick up broadcasts on this ARMER system?
I have not... I was not aware of this issue with the PRO96. Off to read the Wiki. Thanks for your help!Did you try to realign the tuning pots?
It’s outlined in the Wiki and is easy to perform. Almost every Pro96 I’ve ever owned (at least 10 or more) has needed the adjustment. They seem to drift off over the years.
I took a look in the Wiki at this, if this is the process you recommend, it sounds like I need some specialized equipment to do this? The text "Did you try to realign the tuning pots?
I simply used a small flathead screwdriver and made small turns. I kept the scanner powered on with an antenna and locked onto the control channel. As I slowly turned the screw on the tuning pot, I watched the decode rate increase.I took a look in the Wiki at this, if this is the process you recommend, it sounds like I need some specialized equipment to do this? The text "
These VR's should only be adjusted using a calibrated Signal Generator and Frequency Counter." scares me a little bit. ;-)
OK, that makes sense. Thank you for your suggestion!Tuning would also be more reliable if you went to one of the area state prisons where they have standalone ARMER sites instead of simulcast sites to get an alignment.
Thank you for this information and suggestion you provided!I would start by determining whether you are able to receive a control channel for the system. Try manually tuning to the controi channel for the nearest site so it displayed the % decode rate for recieved signal. You may have to try each of the possible control channels until you find the active control channel. Once you determine whether you are able to receive a control channel, next steps can be determined.
You can look at the following post to get an idea of how to adjust VR4 without specialized equipment (YMMV).
https://forums.radioreference.com/threads/modifying-a-rs-pro96 - Post 25
Another possibility, as described earlier, is simulcast distortion. The St Paul site is simulcast (multiple towers transmitting on the same frequency simultaneously). You may want to drive toward the outside of the coverage region to see if you start getting reception. Simulcast distortion is location dependent.
Allied Radio Matrix for Emergency Response (ARMER) Site: Ramsey County Simulcast
Allied Radio Matrix for Emergency Response (ARMER) Site: Ramsey County Simulcast Detailswww.radioreference.com
I went through the entire tuning procedure using professional equipment. The PRO-96 I tuned would still not receive the Baltimore County MD P25 system until I detuned VR4 by about 1 KHz. You need to compensate for frequency drift in the scanner. Frequency accuracy is critical for P25 decoding. Crystals are not rock solid. They usually tend to decrease in frequency as they age. I would limit your adjustment to VR4. It is marked on the circuit board.I took a look in the Wiki at this, if this is the process you recommend, it sounds like I need some specialized equipment to do this? The text "
OK, thank you!I went through the entire tuning procedure using professional equipment. The PRO-96 I tuned would still not receive the Baltimore County MD P25 system until I detuned VR4 by about 1 KHz. You need to compensate for frequency drift in the scanner. Frequency accuracy is critical for P25 decoding. Crystals are not rock solid. They usually tend to decrease in frequency as they age. I would limit your adjustment to VR4. It is marked on the circuit board.
