I have download pro96com. I am using it on my pro 96 and it will pick nothing up at all no tower comtrol or numbers just blank I followed the instructions and I seem not to get it going. Or there is other software to use? Thanks
When you origionally go to monitor the CC in MAN mode does it show 36 or 96 before the SYS ID:, if it shows 36 the system is 3600 and the program will not work with it. The PRO96 works very well with pro96com on a 9600 system, I'm using it now to watch a new system. If your on a 9600 system when you firsdt go to MAN mode the bottom line on the scanner should alternate between something like:bravo14 said:I have tried all kinds of ways. I have the Model: 2000289
Catalog #: 20-289. I am using my pro 96 (Hand Held). I lowered latency and nothing. I have it set to com 1. I didn't see v 1.2.1 build 37 just the 36. I wonder if the handheld doesn't have 9600 and the 2096 does?
If it is Analog it is 3600 - the program won't work.bravo14 said:it is Analog and APCO-25 Common Air Interface. I live St Johns Co 1 south of Duval Co. I am not sure if I have to be in that county to have the software working. I can pick up the signal. I have updated the radio from radio shack.
It has to be all digital to be 9600. I don't know if there is any software for 3600 that will work with the PRO96. Most of the systems in my area are either 9600 or are converting to 9600.bravo14 said:All public safety is all Digital. It still might be 3600. Is there software I can use to pick 3600?
M36 is 3600 system - the % number are how well you're receiving it ,if you can get 75% it should be good, but it would have to be a 9600 system for pro96com. I haven't seen any software that says it will work with the PRO96/2096 for other systems.bravo14 said:Do I have to be in that county to pick up and use the software? I see M36: 9031 75%-45%
I am also looking for some software for Motorola trunked system type I II III
bravo14 said:I have the starrsoft program for the 96. Pro96com I thought maybe I could use that but it only does 9600 and Duval is 3600 so that program is not useful to me.
