Pro96com
boernegang
Boerne,Tx
Good evening, I have a question about PRO96COM. I am monitoring the LCRA system in Kendall County. I see there are two patches that have been up since 20:00 hours on the 20th. My question is: Is there a way to tell who/what agency created the patch??
Good evening, I have a question about PRO96COM. My question is: Is there a way to tell who/what agency created the patch??
If you look at the "PATCH" tab on the left it says FROM TO, that should indicate where it came from I'd think.
mikey60
Oakland County Michigan
That doesn't specifically tell you who set up the patch, it only tells you which talkgroup ID the member talkgroups will be heard on.
wgbecks
NE Wisconsin
The only identity are the patched TGID's themselves. The dispatch center what ever that looks like for your area would be responsible
for setting up and tearing down patches. This is not a user thing that happens in the field.
That is a good indicator though, in the example below Troop H-6 Dispatch is being patched to Troop H-2 Dispatch, so it was most likely setup by the Troop H-6 dispatch center.
boernegang
Boerne,Tx
N1GAW that does help. Looking at it again this morning I would say that some entity in Bexar County has set up the patch. If anyone in the Bexar County area is reading this have you heard anything on this patch?? I've got a BC396XT running PRO96COM on the Boerne LCRA site. I have not logged any traffic on any of the TG's patched or the patch TG that was created. Just curious what it was being used for since it is the "Bexar Common" TG and the "H/C common" TG. Thanks for all the replies!!!!
boernegang
Boerne,Tx
UPDATE!!! I looked around some more and sorting the affiliation log there have been numerous radio ID's that have affiliated with the TG over the past several days. Looking at the Channel Grant Trace it does not show that anyone had keyed up on those TG's that I can see thru the Boerne LCRA tower. Anyone closer to S.A. able to monitor a tower and see if they get any traffic??
