PatrickBW
I picked up a used Pro-96 and I have had many other scanners, but was forced to buy a new one due to rebanding. At any rate, the scanner looked good and powered up just fine. No frequencies were in the scanner so I couldn't test that out. When I did enter frequencies, the unit would not scan. At first I tried to use trunked channels but then reset the unit and tried various (known) standard FM frequencies for local agencies near my home. Still the unit would not scan. I even tried the weather channel button, and there was no audio, but I would hear loud static when the SQ was turned down. Not sure what's going on with the unit, if its user error (okay I shouldn't have pushed that button) or a problem with the radio. I think its the radio as it won't even work on the pre-programmed weather channels, where I only get static over the speaker.
I can't return the radio, so if it appears that there is mechanical error, then it looks like a trip to radio shack for a service event. Please let me now what you thing.
Thank you,
Patrick
Thank you,
Patrick
