Programming a DMR Conventional Networked into a XPR6550 raido
radioguy224
warren county NY UpstateNY
i am trying to programming a Amateur radio systems with a frequency 444.350 and the software keeps on set it back to 450.0000. looking for help on making this work. thanks in advance
K2NEC
NA
Sounds like you are trying to program a UHF1 frequency into a UHF2 radio and it keeps defaulting to the low end of the band split
N4KVE
PALM BEACH, FLORIDA
That literally answers your question. The radio is not capable of 444mHz
It sure is. I have several hi split 6550’s on 440-450 freq’s, & they work perfectly. A simple hex edit using regular CPS takes care of that problem. No “funny tools” needed. There’s hours of reading on that subject.
nhfdcadet
GCT-1
New Hartford, Ct
I'll add the caveat *as it is currently configured*
N4KVE
PALM BEACH, FLORIDA
And specifications not guaranteed.
90% of the local Motorola ham DMR repeaters are 450-512 split. They are hex edited to work in the ham band. If one is buying new, one buys low split. But if buying surplus used, & only hi split repeaters are available, they get used with no degradation in service. The only problem with using a Hi split Moto repeater in the ham band is they won’t play with a Hytera radio. It’s not like we’re asking a 450-512 radio to work at 405 MHz. Just slide down another 10 MHz. Half our group is using hi split radios in the ham band, & no complaints. They were $100 cheaper vs the lo split version.
KevinC
The big K
Super Moderator
Home
Ok, but specifications still not guaranteed.
