programming assistance SDS 100 using uniden sentinel
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
alright i skipped that hoping it works
Still unclear to me what you're talking about. If you're exporting to the same directory where your old .hpe file was you'll need to overwrite it for the file to update. Otherwise you can export it to a different directory
Whiskey3JMC
Resident Numbskull
There's no talkgroup entitled "Baliffs" on the system so you may still be scanning the old FL. Extract the new .hpe file I gave you again but this time choose "Overwrite". You'll need to follow the "Using Sentinel to Import hpe files" directions in the wiki link I gave you & will link again here to import it into Sentinel then write the change to your scanner
Whiskey3JMC
Resident Numbskull
You'll also want to do a site hold on the closest site to you (I noticed you programmed in your county's site & I'm assuming a neighboring county's?) If you scan more than one site then you may miss traffic if you're out of range and/or your talkgroups of interest aren't carried on the 2nd site
Kentucky
Thanks I’ll do that I appreciate your help I have ordered a remtronix 820S antenna. I appreciate your help sorry for making it harder than it needed to be
Kentucky
Well I just set it to all for the time being going to have someone program it. Seems it’s working decent on use database all
