FiberOne
I recently had to replace my Radio Shack Pro-51 due to the squelch malfunctioning. I picked up a Whistler WS1010 400 channel that is, surprisingly, very similar to the Pro-51. I have no problem programing the unit manually as that method is the same with both units. I already have a spreadsheet with the frequency and channels that I created since the Pro-51 didn't have Alpha Tags. Well, neither does the WS1010! For the ease of quickly entering the info, I download two software packages to try them out. I also ordered the programming cable. First is the ARC404 from Butel. I like the mass "copy and paste" feature. The second program is the PSREdit100. Tedious to populate but it does have a column for channel information. The ARC404 got my money and I quickly had my channels and banks ready to upload to the radio. I am using Windows 11 and have the proper drivers installed and the USB port set to COM9. There are traffic lights on the USB plug and they flash when I send. My problem is some frequencies don't end up in the banks I assigned. For instance, I filled in the info to bank 3 and some of them it show up in bank 6. Which I had locked out because I have yet to assign anything and don't need to scan empty banks. When I download from the radio to the computer, nothing changes on my list. I then tried the PSREdit100. This program goes through the motions with the flashing transmit lights, but nothing gets sent. I even went as far as initializing the scanner to first clear all the channels. Then I manually entered all the frequencies, I have them grouped the way I want to match the spreadsheet. I then used the ARC404 to read the scanner and populate the bank list. I wanted to check and compare them to my files. All 400 channels show 20971.518 with Delay ON and Lockout ON. I unplug the programming cable and the scanner is still functioning as it should. With all the channels I programmed in still there.
Anyone else experience something like this? Any suggestions or changes I should try?
